gas tank leaking
Bostons94Vert
The gas tank has started leaking on my 94 vert...it will only leak when over 3/4 is this fixable oer should I get new lines/tank?
New tank, sending unit, and should do a new pump. Lines depend on condition really. Then again the sending unit and pump depend on if you have the money for them.
New tank is pretty cheap about $100 at advance auto, on a 94 the lines leading from the car to the tank will be plastic so they won't be rusty. if the sending unit is all rusty I'd change it too. Personally I'd put in a new pump while its all down but thats just me.
I'd try welding the tank up first.
Otherwise, get a plastic tank.
Why?
Where do you get a plastic tank?
Grease the shit out of the sending unit lines and the top of the tank before reinstalling
