94vertluvr Posted December 3, 2010 Report Posted December 3, 2010 Hello - quick question for you guys. Is there anything unusual about changing out the thermostat in the 3.4L as far as removal and replacement? Do you know what temperature thermostat I should replace it with? thanks for the help guys n gals! Quote
Andrew Posted December 3, 2010 Report Posted December 3, 2010 its straight forward. just use a stock 195 replacement. Quote
Schurkey Posted December 6, 2010 Report Posted December 6, 2010 ...and bleed the air out using the two bleeder screws. Assure that both the radiator and the overflow bottle have the proper amount of coolant in them. (radiator FULL, coolant bottle has an indicator line on it--maybe says "Full Cold" at that indicator line. Quote
