Go4DaMo Posted November 22, 2010 Report Posted November 22, 2010 Hey all, As some may remember, my black 92 Lumina was limped home from Dayton Meet II 2010, with the help of 9Lumina6 and his roommate, Mike. Currently, I've wrapped a full 24 hrs into this car, to no avail. Here's the scoop: Car stalled in traffic. When I turned the key - a repetitive clicking sound was all I heard. I jumped the car off my friend's Cummins...got it home. Since, I've: installed a new battery installed a used starter, removed from an '02 Impala 3400 load tested car for the first time...seemed fine checked grounds from battery checked power to starter...even assisted starter power with a jumper cable going from positive battery terminal directly to the starter. Still, the car barely makes an attempt to start, as if no power is getting to the starter? Any feedback would be greatly appreciated! - Sam Quote
AL Posted November 22, 2010 Report Posted November 22, 2010 Do you have power from the ignition switch to the starter and its possible the clutch switch went bad since its not supposed to start if the clutch pedal isnt pushed down all the way Quote
Go4DaMo Posted November 22, 2010 Author Report Posted November 22, 2010 although I can no longer get it to start from another vehicle's power, my dad managed to. would that cancel these two things out? I messed with the clutch button, even removing it from the floorboard. also, when my dad get my car to start off another car's power, it appeared to not be charging. this makes sense because the entire drive home from Dayton, my phone battery was charging abnormally slowly. Quote
Go4DaMo Posted November 22, 2010 Author Report Posted November 22, 2010 and thanks for the quick reply, Al! Quote
mra32 Posted November 22, 2010 Report Posted November 22, 2010 you can likely easily bypass the clutch switch to see if it is the culprit. You need to figure out if the switch is normally open or normally closed. Well actually you dont you can disconnect the leads to the clutch switch, try to start it. This would be the case if its a normally closed switch. If not try jumping the leads with a wire, this would be a normally open clutch switch. Quote
Go4DaMo Posted November 22, 2010 Author Report Posted November 22, 2010 would a paperclip work? Quote
mra32 Posted November 22, 2010 Report Posted November 22, 2010 not sure, i think from what I read, it was 12 GA wires to the switch, which makes me think power goes through it, so youd want something maybe bigger than a paperclip. got a pic of the connector and wiring? Quote
mra32 Posted November 22, 2010 Report Posted November 22, 2010 I might depin the connector and electrical tape them together for a quick test. Still, I havent seen what the connector terminals look like. Quote
Go4DaMo Posted November 22, 2010 Author Report Posted November 22, 2010 I would presume it to not be these two things, only because those would cause an all or nothing symptom, whereas currently the starter is attempting to start the vehicle, but barrrely Quote
mra32 Posted November 22, 2010 Report Posted November 22, 2010 ok now that I got a good handle on the issue, yes it sounds like the alt isnt charging the system, and its deeply discharged right now. Did you take a look at John's threat about his alternator install on his cutlass? I know thats an OBD-II but it might prove useful to you. http://www.w-body.com/showthread.php/47521-New-Battery-New-Alternator-Not-Charging-(UPDATE-KILLING-ALTERNATORS)?highlight=alternator Quote
mra32 Posted November 22, 2010 Report Posted November 22, 2010 I'll also throw my 'are your battery cables and aux post tight and free of corrosion' in here. Quote
Go4DaMo Posted November 22, 2010 Author Report Posted November 22, 2010 yes I checked all those! I need a rack n pinion, as well...so the subframe's gonna have to be dropped anyway :/ Quote
Hairdo12 Posted November 22, 2010 Report Posted November 22, 2010 What is the voltage accross the battery terminals and what does it drop to when attempting to start. If those test out good, then take the starter out and have it tested. Quote
AL Posted November 22, 2010 Report Posted November 22, 2010 So is it cranking? Or not even cranking Quote
Go4DaMo Posted November 22, 2010 Author Report Posted November 22, 2010 It is cranking weakly...if I bumpstart the car into 3rd gear, it runs fine. Posting this thread was a last-minute effort to avert taking it to the mechanic, but I took it over there today. Thanks for all your input and I'll surely post the result of their diagnosis just to satisfy anyone's curiosity! Again, thanks everyone for your help! - Sam Quote
Hairdo12 Posted November 23, 2010 Report Posted November 23, 2010 mra32 said: I'll also throw my 'are your battery cables and aux post tight and free of corrosion' in here. Also check the ground to the motor and body. What good are connections at the battery if its cronked somewhere else. However I see you Sally'ed out and took it to a mechanic. Quote
Go4DaMo Posted November 30, 2010 Author Report Posted November 30, 2010 (edited) All of the grounds, aux post, etc. checked out. I cleaned them, even replacing one wire. Edited December 1, 2010 by Go4DaMo Quote
Go4DaMo Posted December 1, 2010 Author Report Posted December 1, 2010 Every time I try to post more than a sentence, the website freezes up....it's been doing this for a week. what the heck? Quote
Go4DaMo Posted December 23, 2010 Author Report Posted December 23, 2010 Turns out a ground to the drivetrain was bad, but not the actual wire. Also, a part of the starter solenoid may have been functioning incorrectly. It's back on the road now, though! Quote
