Psych0matt Posted November 21, 2010 Report Posted November 21, 2010 So, I haven't removed one in a long time, so I'm probably going to sound like a newb! I basically realized to get this alternator out it'll be best to take the shaft out, which is fine, I have nothing but time (even though I'd like it done now ). I was just wondering the best route, any precautions I should take, and if there's anything 5 speed specific. I'm sure I'll end up calling Ken at some point anyways but any suggestions, pointers, or tips would be appreciated. I already have the hub off, but I can't find my axle nut socket, so I'll probably have to borrow (or buy) one. Quote
White93z34 Posted November 21, 2010 Report Posted November 21, 2010 you really should not have to for a 284. there is a bracket you can unbolt the side of, and that should give you plenty of clearance to slip it out, you may have to pop the tie rod end off the knuckle though. Quote
Psych0matt Posted November 21, 2010 Author Report Posted November 21, 2010 Elaborate. I have the tie rod end off, and now the brake off and hub bolts. I have the cradle on that side dropped but just cant seem to coax the alt out. It's loose... Quote
Psych0matt Posted November 21, 2010 Author Report Posted November 21, 2010 there is a bracket you can unbolt the side of, and that should give you plenty of clearance to slip it out Chris, bracket for what? The alternator? Tie rod? Maybe theres something I'm missing that's not allowing me to get it out Quote
Psych0matt Posted November 21, 2010 Author Report Posted November 21, 2010 (edited) Ok, I thought about that before but wasn't sure what it was. That'll give me way more than enough room I think. Top bolt, or bottom, or just take the whole thing out? Edited November 21, 2010 by Psych0matt Quote
Psych0matt Posted November 21, 2010 Author Report Posted November 21, 2010 Alright, thanks Chris! Like I said, kinda newbish, I've never done this before and I wasn't sure what that bracket was for Quote
Psych0matt Posted November 22, 2010 Author Report Posted November 22, 2010 Thanks Chris, worked like a charm Quote
White93z34 Posted November 22, 2010 Report Posted November 22, 2010 Awesome! Glad I could help! Quote
Addicted to eaton Posted November 23, 2010 Report Posted November 23, 2010 in your picture what is hanging down thats above the transmission bracket going by the alternator? Quote
