My buddy just got his Monte top swapped but now has a high idle in park but not in drive, heres his video from facebook
http://www.facebook.com/video/video.php?v=10150118810868975
Heres what he PMed me about:
him: so you think a vacuum leak could cause the idle
me: yah
him: cuz it only starts reving higher after a bit
hmm ill have to look around it
me: what do you mean
him: it starts at 2000 rpm
then builds up after mabye 10 seconds to 3000
and idles fine when its in drive
me: spray carb cleaner around the lines and the idle will change if the cleaner get sucked up in there
hmmm ill post on w-body about it
him: i installed a boost gauge too
might be leaking around there
Any other things that would cause that?
The vid doesn't show because of privacy settings.
Did he try and idle relearn?
Dont know, I didnt even know he completed the topswap till he posted the vid... Ill see if I can find an alternate way to post it
last i knew that does not work on a 1st gen..
I know my 99 would rev up with out the intake on it. But would idle fine with the tube on it.
It was originally a non supercharged 3800, but he put the top end of a supercharged 3800 on so its now supercharged
Ok so the IAC is at 130-170, idling anywhere from 2000-3000rpm. Nothing else is wrong but that, and I know its not an issue of the control itself, its where its reading from or the wiring. Any ideas?
Are you running an L36 or L67 MAP sensor?.....idk if that would really matter...but just curious. And check all the vac lines to make sure they are routed correctly. Also....maybe change the PCV valve in the blower...
I don't know if the sensor itself makes a difference, but I'd suspect it does. Keep in mind, a supercharger does it's best work a lower RPM...which, when you stop and think about it, would reduce engine vacuum...just like a vacuum leak.
I was under the impression the PCM programming was different on the L67?
Its been tuned and the SC belt isnt hooked on yet, so its not an issue of that. Ive triple checked the vacuum lines already. What sends the code to the IAC?
Ya know...I wonder if the sensor itself is just bad. Did you swap sensors over from the L36 TB to the L67 one? I'm not 100% sure if the part #'s are different.
  • 2 weeks later...
