What 282 5 speed parts do I need?
Got a deal on a complete Getrag 282 5 speed setup; everything from the interior, minus the left-right shifter cable as that broke, for $250. The trans is rebuilt, comes with an additional rebuild kit, and axles as well.
I need to tell the guy who's parting the car out what to pull. Can someone please give me a complete list of parts that I can give him so he knows what I need?
Thanks!
Edited by xtremerevolution
The search button is your friend. I did the same thing in March.
Aluminum mag bracket w/ pedals
Hydraulic clutch linkage
Shifter
Cables
Cable to trans bracket
Trans
Axles
Intermediate shaft bracket
And I think thats pretty much it. If you have any questions feel free to pm me.
Ken mentioned some shifter to floor pan clips as well. Any other small odds and ends?
Axles
Trans
Trans mount
Clutch slave
Hose from master to slave
Clutch master with reservoir
Brake Booster (not sure, was told once it is different.)
Firewall plate
Neurtral Safety Switch
Shift cables
Shift cable bracket on trans (easily misplaced when removing cables)
rubber grommet for shift cables
Shift lever assembly
Retaining clips on body (looks like a stud with a flat metal clip on it)
Shift boot/console
Shift knob
Clutch, Pressure plate, flywheel.
If you have column shift, you may want the steering column too.
I don't think a 5 speed will be column shift. :lol:
Thanks for the list though.
If your automatic is currently column shift....
Ah, that makes sense. Nah, mine is floor shift. :)
Axles
Trans
Trans mount
Clutch slave
Brake Booster (not sure, was told once it is different.) You need a 88-93 small brake booster
Firewall plate You can modify the stock one (cut it) for mount the clutch master cylinder
Aluminum mag bracket w/ pedals A early model like a 94 and down already has the spot for the clutch pedal, just add the pedal
Neurtral Safety Switch I have verified 94 2.2 cavaliers have the same one, so those years will have one you need
Shift cables
Retaining clips on body (looks like a stud with a flat metal clip on it) I got ones from a 94 2.2 Cavalier which are the same
Shift boot/console
Shift knob
I added a few info tidbits. But thats what you need.
Don't forget to get all bolts, I left the flywheel bolts at the Junk yard 200 miles away,:bang: IIRC it took some time to find a new set.
