Fuel Pump is dead after 30 min. What would cause it?
Brand new Wal-bro pump ran well for about 30 min. I had some issues with the fuel pump relay at first and was diagnosing a vacuum leak when the car died and the fuel pump won't run anymore. :cry:
I should mention I'm running an OBD II Engine harness from a 99 Chevy Lumina with L36 adapted to the original TGP Harness
Not sure... Faulty unit? Double check your getting power to the unit and is there any kind of warranty on the pump
There is power I went all the way back to the harness in the trunk and applied power and ground to the two leads and nothing. Totally garbage. Unfortunately I bought the pump over a year ago when I was putting everything together, and the warranty is for a year from date of sale, which really sucks for me.
Id call them and explain to them that when you installed it. It only ran for 30 min. They would likely replace it.
