EGR bolt size?
update: I ended up using the bolt from the hold down tool i made, the M8 1.25 X 50mm and just used 2 pressure washers on the top and would you belive it worked like it came from the factory? :-D
Gasket is ripped to shit though, could that be causing my high idle at 1.2K??
Yeah, basically its a huge vaccum leak, try some high temp copper sealant on that gasket if you can't find a new one.
i have some gasket making paper, could i place it on the gasket paper and just remold/template-off the egr to make the gasket out of that paper??
You can do that as long as your gasket material will hold up to the heat from exhaust gasses.
You're better off just gettin a new EGR to plenum gasket, its like $2. I wouldnt make any gasket that has exhaust gasses around it out of paper
