boostnawd Posted October 5, 2003 Report Posted October 5, 2003 Trying to get an idea of what/where it could be.. it's coming from between the firewall and motor - of course, not much room there to poke around. There is a plastic white tube (cruise cntrl???) that is disconnected, I have a feeling that's what it is.. where is it supposed to connect? I was replacing the breather (plastic) hose that plugs into the air "accordian" hose that plugs into the tbody and I must have yanked that white plastic one out in the process. Doh! Quote
boostnawd Posted October 6, 2003 Author Report Posted October 6, 2003 Car runs fine, the hissing has me concerned. I'm guessing the intake plenum has to come off to get a look at what's back there? I have what appears to be a vac diagram in the engine bay, only it's very faded. Anyone point me to one on the web? Quote
Aaron Posted October 6, 2003 Report Posted October 6, 2003 id like to see it if you find one. i had a vacuum leak that i found while tearing my car apart. it hissed really badly, and wouldnt idle wrth a shit. it was a large rubber tube that ran under my plenum that got a hole/slit/cut in it. Quote
Bolt_Crank Posted October 6, 2003 Report Posted October 6, 2003 id like to see it if you find one. i had a vacuum leak that i found while tearing my car apart. it hissed really badly, and wouldnt idle wrth a shit. it was a large rubber tube that ran under my plenum that got a hole/slit/cut in it. I have a little black plasticy rubbery hose that's been crappilly patched.... it hisses a lot when the shifter is in 1st Quote
icfshadowone Posted November 4, 2003 Report Posted November 4, 2003 On mine it was the PCV valve that sits next to the tranny dipstick. Quote
Aaron Posted November 4, 2003 Report Posted November 4, 2003 it was the PCV valve, came out from below the lower intake, years of heat, exhaust gasses, and gas gasses and such wore it out, it felt like flexpipe so i got a new one, and i COULDNT move it at all, and it didnt have the tear that the other one had. maybe it wasnt supposed to..... Quote
joey b Posted November 5, 2003 Report Posted November 5, 2003 perhaps the one that plugs into the rear valve cover. It is about half way back and connects to a T connector. Quote
