95 Monte cruise and gauges stop working, fuses good
I have a 95 Monte Carlo and my cruise, speedometer, tach, fuel, and coolant gauges all stop working. Couldn't find any blown fuses.
Thanks
Scott
Possibly as simple as a main harness/ plugin/ connector, if everything just up and turned off.
You looked under the hood and in the glove box (I think thats where the interior fuse box is on that generation)?
I have a similar problem on my CS. All my gauges share the same ground in my cluster and the wire is loose in the connector so every once in a while I have to mess with the connector to fix the problem.
