94GPGTP Posted October 23, 2010 Report Posted October 23, 2010 I noticed a bad wobble side to side from the engine and tranny causing the car to shake side to side.. It does it real bad in 1st,2nd,3rd but 4th, and 5th its not as bad.. upon hard accelaration and getting into boost it feels like the wheels are going to fall off.. I have checked the ball joints they are tight, tie rods are tight, wheel bearings are new, both outer cv boots have a hole in them and the grease has flung out.. Is it possible for the cv axles to cause this? as like possible binding? This is in my TGP with the getrag 282.. Quote
BXX Posted October 23, 2010 Report Posted October 23, 2010 could be binding halfshafts, or blown mounts. Possible loose subframe or bad bushings on the control arms. btw, did you get my PMs aboot the clutch pedal? Quote
94GPGTP Posted October 24, 2010 Author Report Posted October 24, 2010 the trans mount is in very bad shape but all other 3 in very good shape.. i dont see the trans mount causing this because the trans mount has been in poor shape since the 5 speed install.. i didnt have a problem with it before.. The lower control arm bushings are poly's so i dont see that being an issue.. i can double check the subframe bolts.. Just got back on the site since i havent been here in a few weeks.. ill check to be sure i have the pedal.. Quote
mra32 Posted October 24, 2010 Report Posted October 24, 2010 Have you considered that its really a 284? Quote
