I want to fix the primered look on my my car and I was wondering what the paint code was. Its the white from 89 not the newer white that the 91's used.
The paint code should be on the RPO tag on your car, if it's the same as the later 1g's it's on the spare well cover.
looks like it'll be arctic white?
I believe the older white is WA8554(GM white), but you should confirm that somehow.
thanks! My main concern to fix this was because when i went auto Xing about a month ago when I took the numbers off it peeled the paint with it only on the drivers side. I think Im going to look a little more into it tomorrow check them codes possibly order some paint
