crazyd Posted October 11, 2010 Report Posted October 11, 2010 I've got a leak coming from inside the bellhousing of my 284. I see the input shaft seal is available on RockAuto. Can I actually replace it? Can it be replaced without disassembling the trans? Or, can this be "dealt with" some other way? Or am I just SOL and need to replace the whole trans? I've opened up a broken 284 before. I just don't know how to put one back together. Quote
AL Posted October 13, 2010 Report Posted October 13, 2010 If its coming from the bellhousing I don't see a way of "fixing" it without pulling the trans and at that point you can see exactly what needs replaced Quote
crazyd Posted October 15, 2010 Author Report Posted October 15, 2010 I'm well aware I need to pull the tranny. What I need to know is whether I can actually do anything about it once it's out, or if I'm just going to have to replace it anyway since there's so little that can be done to repair these transmissions. There does not appear to be a seal on the input shaft in the service manual. Quote
crazyd Posted November 3, 2010 Author Report Posted November 3, 2010 It took me a couple weeks to get things coordinated so I could pull the motor out, but I finally got it done this past weekend. Obligatorypic: It turned out to be the detent cover as I'd hoped. I don't know why it popped out, but I hammered it back in and glued it so it stays put this time. My oil pan is pretty beat up, so I'm also taking this opportunity to replace it while the whole thing is out of the car. My transmission mount is broken, however. Has anyone found a replacement or a suitable substitute for these? Quote
intern8tion9l Posted November 4, 2010 Report Posted November 4, 2010 were you able to lift the engine and trans out as one piece? Quote
crazyd Posted November 4, 2010 Author Report Posted November 4, 2010 jimmyfloyd said: which transmission mount? 284's only have one mount. intern8tion9l said: were you able to lift the engine and trans out as one piece? Yes, I've done it this way several times before. It is only possible with a load-leveler as seen in the photo above, but the 284 is small enough to sneak past the ABS/MC if you angle it just right. I remove the slave cylinder and accumulator as well as the A/C manifold lines and accumulator, and it all comes out in one big lump. The unpleasant part is having to R&R the clutch just to get the throwout bearing out of the pressure plate. I broke three pairs of snapring pliers before finding a set that was strong enough to release the TOB. Quote
intern8tion9l Posted November 6, 2010 Report Posted November 6, 2010 i'm doing an engine/trans swap soon, i was hoping to lift and set them as one piece cause i HATE having to align the input shaft Quote
