my car started now what is this noise page 2
LQ1 has a WHOLE lot of lifters.... i have a hard time believing it's coincidence though...
well is it possible for a engine to sound like that if its not firing right?
but then again is running to smooth to be on 5 cylinders
a guy on gmfourm suggested x over that is where it is loudest
it's possible... not sure how it could have gotten into the oil that quickly though, especially since it didn't flat out die on you somewhere...
and the crossover is possible, especially if it got wet while hot, that tends to distort them, potentially enough to make a gasket leak....
yeah and i dont think i have water in the oil as it is still brownish and slick
oh it got wet it has waterspots all over it
hmm, that may explain it then.
from the looks of it, i'm not even sure if a gasket is used between the logs and the crossover...
yeah im gonna look it over tommorow when i have a day off as i have already planned rides out for the day:lol:
Sounds like a lifter tick to me. Get it up to operating temp and see if it goes away.
I'm still thinking arcing...since you've got a garage, wait till dark, make sure the garage is very dark, with your eyes adjusted, and start it up. Cheap and easy way to look for arcs...and it can't hurt anything.
well i can do that now it will get very dark in there
im thinking if it is arcing tommorow i will pull all the plug wires put dielectric grease on them, reconect and see what happens as i did forget that step when doing my plugs
not only does it seal out moisture, and seal in the spark, it makes wire removal easier and less likely to rip a terminal off of the wires.
wonderful stuff.
okay well i started my car again and now it sounds like is on 5 cylenders so im sure its spark knock we shall see in the morning
tick is mostly gone dielectric grease quieted it and then after a drive it was gone compleatly, but now it is still running like shit i ran it up to 4500rpm and it hardly got to 30 felt like it had a 3100. and i have a whine from the pass side. im thinking the whine was from the belt area as i had less ps assist
if one of the cylinders had no spark, the plug is likely fouled... pull them until you see one that's black as night, and that was likely the one that was misfiring.
hell, it's a LQ1, pull all of them and clean them up with a brass brush or brake cleaner.
