visitor Posted October 2, 2010 Report Posted October 2, 2010 Hello, my STE has a power sunroof, and the instalation seems well done, but the switch doesnt look anything relating to factory.. Its got 3 seperate switches as you can see (one for overall power, one for vent, and one to open) Were all STE's like this, or did a prior owner have this added? (FWIW- it works, although slowly, and does NOT leak) Quote
94 olds vert Posted October 2, 2010 Report Posted October 2, 2010 It isn't factory and ASC didn't sell their sunroofs to Pontiac. Quote
Twenty Posted October 2, 2010 Report Posted October 2, 2010 And I don't think factory sunroof-equipped cars had the overhead consoles. Quote
GOT2B GM Posted October 2, 2010 Report Posted October 2, 2010 Thats aftermarket, but don't worry about it, I have an aftermarket power sliding roof in my Z34 from 1992 and its better looking install than the factory roof in my TGP. Quote
visitor Posted October 2, 2010 Author Report Posted October 2, 2010 Thanks for the quick responses! Just need to make sure the drainage tubes are clear (and routed correctly.. Seen some bad stuff out of aftermarket sunroofs) Quote
GOT2B GM Posted October 2, 2010 Report Posted October 2, 2010 where do your drain tubes terminate, mine end at the base of the a pillars on my Z. Quote
visitor Posted October 2, 2010 Author Report Posted October 2, 2010 Looks to be the same place. Ill tear it down more and check further next week sometime Quote
Addicted to eaton Posted October 3, 2010 Report Posted October 3, 2010 ASC made the B4u effects on the 1st gens. That being said my 1996 Cutty had an aftermarket sunroof that was faster, better sealing and quiter then my 99's or 97's GTP's Factory sun roof. Quote
w-bodys_are_the_best Posted October 6, 2010 Report Posted October 6, 2010 ASC made the B4u effects on the 1st gens. That being said my 1996 Cutty had an aftermarket sunroof that was faster, better sealing and quiter then my 99's or 97's GTP's Factory sun roof. And closed automatically 30 seconds after the key was shut off, at least when I had it it did. I can't remember if it did after the fuse box was re-installed, may have used a different power feed, can't remember. Quote
