Dark Ride Posted October 2, 2010 Report Posted October 2, 2010 I want/need to put new brake lines in the TGP, how do you get that goofy flare where it meets the hose? The parts store carries bend-it-yourself brake line, but standard flares. Quote
Schurkey Posted October 2, 2010 Report Posted October 2, 2010 (edited) Mastercool 71475 is about the best way I know of. http://www.mastercool.com/pages/flaring_tools.html Available at discount from any of a dozen internet tool sales companies. Manual tubing flare sets are available, but not nearly as much fun. Good luck bending the tubing tight enough without kinking unless you use a QUALITY tubing bender. It might be possible...certainly not worth the arthritis in the thumbs for me. https://www.flowline.net/default.aspx?page=item%20detail&itemcode=364-FH-03 (example for 3/16 tubing) Don't forget the metric tube nuts. Edited October 2, 2010 by Schurkey Quote
ManicMechanic Posted October 2, 2010 Report Posted October 2, 2010 Good luck bending the tubing tight enough without kinking unless you use a QUALITY tubing bender. It might be possible...certainly not worth the arthritis in the thumbs for me. I've filled them with sand and taped the ends good and tight before bending. Works great. Make sure to flush the sand out of course. Quote
BXX Posted October 2, 2010 Report Posted October 2, 2010 seriously?? 3/16ths brake line doesn't require a tubing bender. Line that small is easy to bend and kinking shouldn't be an issue unless you aren't paying attention. A generic flaring tool kit will work fine. Autozone rents them as a matter of fact. Quote
GOT2B GM Posted October 2, 2010 Report Posted October 2, 2010 I have a tube bender which works great for making tight bends, but if all your bends are gradual then you should be fine by hand. Quote
Dark Ride Posted October 2, 2010 Author Report Posted October 2, 2010 I've never had problems bending the brake line. I was just wondering about the flares. Autozone rents them, and they can do bubble flares? My dad has a flaring tool, but it only does standard flares. Quote
carkhz316 Posted October 2, 2010 Report Posted October 2, 2010 If you get a flaring tool or rent one, make sure it can do a double flare. It's the only way to go with brake lines to withstand the high psi of the brake fluid. Don't use any other type of junction because it can leak. Quote
BXX Posted October 2, 2010 Report Posted October 2, 2010 you can do a solid bubble flare by only doing the first parts of a double flare. But only do the first part of the flare about 80 percent. Quote
Dark Ride Posted October 2, 2010 Author Report Posted October 2, 2010 If you get a flaring tool or rent one, make sure it can do a double flare. It's the only way to go with brake lines to withstand the high psi of the brake fluid. Don't use any other type of junction because it can leak. Do you or the shop you work for have one? If I brought you some brake line could you show me how to do it? Quote
