Warning lights, how to fix?
Ok, so the brake light is constantly on, the ebrake is busted, whatever.
But there are two that I have questions on. The gas light is always on, yet the gauge works just fine (a little off centered, but find none the less). What trips this up and should this be an easy fix?
Also, my coolant light is on almost constantly. Sometimes it goes off and or flickers for a bit, but usually on despite the gauge working 100% perfectly. What sensor is this one? I've never done either of these on any of my Ws, so sorry for sounding like a noob :D
low fuel light? don't suppose this is in a 88-93 GP UB3 cluster? and for coolant, is it level or temp?
its the coolant temp sensor, right by the temp gauge. And no, its just the regular analog dash, but it does have the little info center on the lower left which is where the low fuel is. When I first fill up sometimes it goes off, but not usually.
