Looks like after 14 years my 96 Regal needs new rear struts. The rubber bumpers are rotten and it and the dust shield have dropped down on the shock.
I have read that the Monroe Sensa-Trac Strut will give the softest ride is this fairly accurate?
When replacing the rear strut how do you deal with compressed rubber auxiliary spring?
The rubber auxiliary spring is painted gray in the lower picture.
They have compressors for them. Looks like a pretty good deal for one of these: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130432993501&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=f185c70312a0a02663b144c1ff921208&rvr_id=146171342276&ua=WXS%3F&itemid=130432993501
Many cars did not get those and so people have left those off without issue. Including myself. But I was switching to coilovers. YMMV
I don't know if that style aux springs has a hole (looks like it might), but usually you can compress them using a bolt of a specific size. I'm sure the size has been posted before.
everytime I've bought rear struts for my wbodies they came with the correct bolt to thread in and hold the aux spring.
You're right, come to think of it, my spring compressing bolt must have come with the struts because I don't remember buying a special metric bolt. It would probably be hard to find one by itself.
I compressed my aux springs in a vise, used some wire to hold them compressed. Once installed, I cut the wire.
I just did this few a months ago and fought like hell with that rubber spring. I was tempted to not install it. I finally used a wood clamp to compress it at the same time as getting 1 of the lower strut mount bolts in. The other side went together in a few minutes. Its a pain, but stick with it and try various clamp setups - it will go back together:)
I left those things off of my car a long tim ago. Never noticed a difference, but I reduced unsprung weight.
Edited by xtremerevolution
Thanks
Compressing the auxiliary rubber spring using a bolt worked great.
I used a 6-inch long all thread bolt 3/8 inch OD by 16 threads per inch along with a matching nut and thick washer.
  • 5 years later...
Warning I used the wrong bolt listed above.
The correct bolt to compress the auxiliary rubber spring should be 10 mm x 1.5 thread pitch about 6 inches long.
