Knock, Knock, Knock....
Addicted To Boost
What would cause a knocking noise (not deep, yet louder than just a tick) and smoke that smells like oil? I know its a vague description, but I need some ideas. I have good oil pressure and the oil level is good.
Dropped valve? Scored main bearing (high miles) Not much to really work with lol.
It can't hold an idle at all now and it sounds like its misfiring quite a bit in the exhaust. Cruising in OD at 55, the car just shakes, but the tach stays rock solid, I have a solid 40 PSI of oil pressure cruising around and 20 PSI at idle. Only has 129k... :dunno: It JUST started doing this today too... Ran absolutely perfect prior to this.
The knocking is steady and increases in frequency as RPMs increase, also decreases in speed the lower the RPMs are.
I'd be doing a compression test and pulling valve covers.
Compression test reveals... 170 PSI on all cylinders... except cylinder #3. Cylinder #3 has 0 PSI and the spark plug is black and wet.
RIP TGP :cry:
if it actually dropped the valve the piston would shatter. I know, I have a l67 in my garage that suffered the same fate.
pull the valvecover and look for a broken valvespring. If so, replace it and see if you can't salvage the engine enough to make it run and quite down
Wouldn't it have the same effect if a lifter broke or if I lost a cam lobe? Its pretty common to have cam lobes wipe out on TGPs...
yes, but valve springs break often too on Gen 2 660s
might as well pull the valve cover to get an idea of what is actually wrong.
