white4d96 Posted September 13, 2010 Report Posted September 13, 2010 (edited) I'm in the process of swapping leaves (and replacing two bent lateral links.) While unbolting the two brackets that hold the spring to the cradle, one bolt on each (the rear one I believe) snapped off. Is it safe for me to just tighten the one bolt down? If not, how the hell am I supposed to get this broken piece of bolt out? There was so much friction that at one point the front bolts were smoking heavily, even with lots of WD40, so I'm concerned about getting enough torque with an easy-out or similar contraption. I wish I could just forget it and go coilovers but due to blown rear shocks and cost that is not an option right now. Thanks in advance. Edited September 23, 2010 by white4d96 Quote
Addicted to eaton Posted September 13, 2010 Report Posted September 13, 2010 If it was me i would try and easy out. If not? Id try to weld a bolt to it. Quote
white4d96 Posted September 13, 2010 Author Report Posted September 13, 2010 I might try one tomorrow. Failing that, maybe I'll just piece the car together so it's not resting on stands and save up for coilovers. It's just been a really frustrating night, between the aforementioned problem, finding a bunch of nasty rust spots, and just having a b***h of a time with getting the subframe out and apart. Hopefully tomorrow's a better day. Quote
Crazy K Posted September 13, 2010 Report Posted September 13, 2010 Having broke both bolts in one of those and driving the car for three years before fixing it..... I would try to fix it. here is the easiest thing to do: GO TO THE DEALER AND SEE IF THEY WILL SELL YOU NEW INSERTS. the insert is easily removable if there is no bolt stuck in it, and for my car and I actually pulled a used one out of a junker after successfully pulling it's bolts out. There is access pass though hole that can be used if the lateral link is moved out of the way, but with a broken bolt you will have to wail on the old retainer clip until it breaks into pieces to come out. once out stick the new one in (preferably get new bolts from dealer?) crank it down with some thread lock on the threads and then liberally grease and pb blaster the clip so it will not fail again...... p.s. pm me if you cannot get the clips, I should have some. Quote
white4d96 Posted September 13, 2010 Author Report Posted September 13, 2010 You wouldn't happen to know the part numbers would you? Quote
Crazy K Posted September 13, 2010 Report Posted September 13, 2010 sorry, I do not.... but a good parts man at the dealer should be able to show you a diagram and find it......... Quote
white4d96 Posted September 14, 2010 Author Report Posted September 14, 2010 Well now I got bigger issues to deal with. Trashed one of the knuckles trying to bolt the caliper bracket back on. Guess the car's gonna sit for a while. Quote
Crazy K Posted September 14, 2010 Report Posted September 14, 2010 ????????????????????????????????????????????/ Quote
white4d96 Posted September 14, 2010 Author Report Posted September 14, 2010 Basically a lot of shit is going wrong at the same time now. I got the knuckle-caliper bracket issue sorted (I think). No dealer in my area seems to want to deal with me and my old car so I guess I'll just tough it out until I go coilover. Quote
Crazy K Posted September 14, 2010 Report Posted September 14, 2010 talk to us and we can help you with whatever you need.... and FUCK THE DEALER. (usually) the parts you might need could be easily be found in good used condition in cleaner areas of the country.... even I have the parts you are implying you need..... Quote
white4d96 Posted September 14, 2010 Author Report Posted September 14, 2010 If I can get those damned bolts out I can use the ones I have. I'm just worried about breaking an easy-out before the bolt even turns, especially since it wouldn't be mine to break. Turns out my friend's dad has some so I might try again later in the week. At least the car's together and drivable for now, just gonna take it easy and no long trips until I get it sorted. Those bracket/mount jobs sure are talkin', but they're holding for now. Quote
white4d96 Posted September 20, 2010 Author Report Posted September 20, 2010 I found the source of the noise: Both of the mounts for the sway bar are snapped, and the bars themselves are kissing the rear lateral links. I'll just pull the bar for now until I can either get a Lumi one or figure out what I did wrong routing-wise.I'm just baffled because I didn't even remove the sway bar; I just pulled the whole subframe out. Quote
Crazy K Posted September 20, 2010 Report Posted September 20, 2010 You just need new extension arms from the swaybar to bracket... believe it or not, I have these too..... Quote
White93z34 Posted September 20, 2010 Report Posted September 20, 2010 dealer can get those brackets brand new for 11-15 each. Quote
white4d96 Posted September 20, 2010 Author Report Posted September 20, 2010 Lol damn Crazy, is there anything you don't have? =P I have credit for the local Pick N Pull so I'm gonna swing by there in the morning and see if there's any Z34 bars. Figure since the bar's out, why not put a better one in? And I figured out what I did. Stupid me put the bar back in upside down. Don't ask me how; I don't remember taking the sway bar off the struts. Quote
Crazy K Posted September 20, 2010 Report Posted September 20, 2010 (edited) i agree... get a bar from any 3.4 gen 1 car.... or upgrade and use a bar from a gen 1.5 with a little more work... I have the cage reinforced brackets needed to use the 1/2" gen 1.5 bar (the smallest of the three gen 1.5 bars they offered) on a GEN 1, which is thicker than a 3.4 gen 1 bar... so you know: (sizes are approximate, I need a caliper...) gen 1 small bar: 5/16" gen 1 large bar: 3/8" <--gen 1 3.4, possible 3.8 cars gen 1.5 small bar: 1/2" gen 1.5 medium bar: 5/8" gen 1.5 large bar: 3/4" <--- 1995 gen 1.5 3.4 ONLY. Edited September 20, 2010 by Crazy K Quote
white4d96 Posted September 20, 2010 Author Report Posted September 20, 2010 What kinda mods are needed to fit a 1.5 bar? Can I just use its factory brackets? Quote
Crazy K Posted September 20, 2010 Report Posted September 20, 2010 What kinda mods are needed to fit a 1.5 bar? Can I just use its factory brackets? only if you weld a cage to the bracket, as the bar is actually 1 inch wider and works only if compressed into position, but then it pushes out on the bushing, so the caged bracket prevent the bushing from popping out. ...and only the smallest gen 1.5 bar works with this trick. Quote
white4d96 Posted September 20, 2010 Author Report Posted September 20, 2010 Alright, I'll just get a 3.4 bar then. I don't have access to a welder. Quote
white4d96 Posted September 20, 2010 Author Report Posted September 20, 2010 Joke's on me, between my last trip to the junkyard and today they crushed all the LQ1 cars there. I'll just hold out until they get a new one in I guess and hopefully it'll have a good bar in it. Quote
white4d96 Posted September 21, 2010 Author Report Posted September 21, 2010 What all is involved in welding in this cage for a 1.5 bar? Do you have pics? They have like 8 of the damned things there now so I figured that's my best bet for a sway bar. Quote
white4d96 Posted September 22, 2010 Author Report Posted September 22, 2010 Someone? Anyone? I'm kinda wanting to get this taken care of, sick of not having a sway bar. Quote
Addicted to eaton Posted September 22, 2010 Report Posted September 22, 2010 Im not really sure but id guess weld a U like metal peace over the top top hold it in place? I could be VERY wrong. Quote
white4d96 Posted September 23, 2010 Author Report Posted September 23, 2010 Kabump. I might just pick up a 1.5 bar and see what I can do to make it work for now. Would it be possible to just cut the ends down to size? Or would that not be a good idea? Quote
mra32 Posted September 23, 2010 Report Posted September 23, 2010 you might be able to carefully bend the ends in with a long pipe and a few friends Quote
