WhatTheFehl Posted September 10, 2010 Report Posted September 10, 2010 The car has done this a few times by now, I've noticed. Last night on my way home from a BSA District Roundtable (also Order of the Arrow) meeting, I pulled out of the parking lot and decided to open up the car a bit. I hadn't done it in a while, so I figured I might as well. I put the pedal almost to the floor, and it behaves normally... then for a split second right before it drops into 2nd the battery light on both the gauge cluster and the HUD flashes. It just barely catches my eye, by the time I focus on it, it is gone. I try doing WOT twice more on the drive home... and I cannot get the light to come on again. Anyone have any clue WTF is going on here? The battery is less than a year old, the alternator is working fine according to the tester I have. Quote
RobertISaar Posted September 10, 2010 Report Posted September 10, 2010 you're absolutely sure it was the battery light? Quote
WhatTheFehl Posted September 10, 2010 Author Report Posted September 10, 2010 My initial instinct was "Maybe it was the engine light, maybe the transmission hesitated just enough to make it flash the light"... but when I got home and shut off the car, and turned it back to run, when all the lights go through the test phase it was the red one that is shaped like a battery on the upper right hand side of the gauge cluster, above the speedo... same on the hud, upper right. Quote
RobertISaar Posted September 10, 2010 Report Posted September 10, 2010 could have been a one time glitch... or possibly a loose connection somewhere. Quote
WhatTheFehl Posted September 10, 2010 Author Report Posted September 10, 2010 It has done it before, but when I try to replicate it I can't make it happen. As near as I can tell, it was the battery light. It wasn't the SES light because that is orange and does not display on the HUD. It wasn't the security light because it wasn't a word... it was a symbol... plus I don't think the security light displays on the HUD either. Quote
RobertISaar Posted September 10, 2010 Report Posted September 10, 2010 i'd be looking for a wire that is wiggling it's way loose... only happen at WOT, or other violent movement? Quote
WhatTheFehl Posted September 10, 2010 Author Report Posted September 10, 2010 Only ever noticed it at WOT. Quote
RobertISaar Posted September 10, 2010 Report Posted September 10, 2010 sounds like an intermittent disconnect IMO. i'd check along where all of the large guage wires run that connect the alt, battery, electrical centers, remote positive terminal and down where they meet at the starter solenoid. Quote
Galaxie500XL Posted September 10, 2010 Report Posted September 10, 2010 Could be a slipping serpentine belt...or the tensioner going south, and not able to keep the belt from slipping at WOT... Quote
RobertISaar Posted September 10, 2010 Report Posted September 10, 2010 that also would make sense. Quote
ruktosk Posted September 10, 2010 Report Posted September 10, 2010 Could be a slipping serpentine belt...or the tensioner going south, and not able to keep the belt from slipping at WOT... x2 Quote
WhatTheFehl Posted September 10, 2010 Author Report Posted September 10, 2010 The belt looks brand new. I imagine it was replaced not long before I purchased the car (along with the radiator hoses that still had the little Carquest stickers on them) Quote
Regal_GS_1989 Posted September 15, 2010 Report Posted September 15, 2010 Your car doesn't have a check guages light by any chance does it? I know my cutlass used to light the check gauges light whenever the tach would hit the amber zone. So it would flash pretty well everytime I went WOT. Quote
Crazy K Posted September 17, 2010 Report Posted September 17, 2010 Your car doesn't have a check guages light by any chance does it? I know my cutlass used to light the check gauges light whenever the tach would hit the amber zone. So it would flash pretty well everytime I went WOT. The feature you describe is part of the 92-94 CS guage clusters.... and not this cluster. interesting point, though. check the tensioner for side to side movement. replace if excessive. TIP: get a used tensioner from a 88-92 2.8/3.1, they are heavier duty than later tensioners and the same size. tighten the aux post and the wire on the back of the alt. Quote
