91eurocpe Posted September 9, 2010 Report Posted September 9, 2010 Where can you buy the 3 port rubber vacuum connect on the throttle body 1991 ero lumina 3.1 L Quote
mediabandit Posted September 10, 2010 Report Posted September 10, 2010 How many more threads you going to open for this? Quote
mfewtrail Posted September 10, 2010 Report Posted September 10, 2010 Dealerships should still carry them, but it will probably include the entire vacuum "spider"(all the hard vacuum lines that attach to the throttle body block and run under the upper intake to various things). Should be around $30-35ish for the whole assembly if I remember correctly. Quote
91eurocpe Posted September 10, 2010 Author Report Posted September 10, 2010 i kept getting an error message when i tried to post sorry Quote
chrisflstf Posted September 10, 2010 Report Posted September 10, 2010 You can buy just the T-connector at the dealer. Its about $3. Dont have the p/n handy, but I can get it. In my city, the Buick dealer even told me what other dealer had them in stock. So I picked one up at the Chevy dealer, who had it in stock Quote
91eurocpe Posted September 10, 2010 Author Report Posted September 10, 2010 mine is loose and keeps falling out Quote
chrisflstf Posted September 10, 2010 Report Posted September 10, 2010 You can use a ty-wrap as a temp fix to tighten up a loose connection, as long as the rubber is not split Quote
mfewtrail Posted September 10, 2010 Report Posted September 10, 2010 i kept getting an error message when i tried to post sorry Even if you get an error while posting, refresh the section that you're viewing to see if the post went through. Often times, they get posted even when you get some types of errors. Quote
