Oil Filters ? Wix #51040 versus the Wix #51036
Wix part number 51040 versus 51036
The 51040 seems to be at least an inch shorter then the 51036
Does this effect oil flow ? and add a restriction or would the taller filter improve oil flow and filter more at the same time or is this really a none issue as long as a quality filter is used ?
I also have read really good things about the PURE ONE oil filters. but is a taller filter really better ?
the 040 is likely the WIX version of the PF52, and the 036 is teh WIX version of the PF47.
i ALWAYS use 52 style filters whenever possible.
My Regal takes the 51040 filters. Never had a problem with them. Honestly, the only difference between the 2 is the size...the 36 is taller, and would give you some extra filtering material. The base plates on the 2 of them are identical....so i don't see an issue with using either one as long as you have the proper clearance for a taller filter. If you have a 3100, then there should definitely be no issues with the taller filter. Only reason I use the 40 is because the filter is right above the passenger side control arm, and I wouldn't want to risk the taller filter getting hit during suspension travel. There may be clearance, but i've never bothered to investigate it fully.
And Rob...you've got it backwards...the 40 would be the equivalent of the PF47, no the PF52.
Thanks Regal_GS_1989
you're probably right, i assumed WIX would have used the larger number for the larger filter, the same way ACDelco did...
but yeah, if there's clearance, it never gurts to have more filtering material and oil filter capacity.
Ive always run the bigger Pure One filter. No clearance issues on the 2nd gens til you are lowered.
There was a thread that I read about oil filters and it gave the Pure One a higher rating than the WIX, and I thought that they were both a WIX filter.
Maybe the Pure One is there top of the line ? I dont know but I think I'm going to start using them. Whats the part number for the taller Pure One ?
Thanks again :)
No. Puroilator is a different manufacturer then Wix. Both are good filters though.
Purolator PurOne long filter is # PL24011
Purolator standard long filter is # L24011
Purolator PureOne short filter is # PL10111
Purolator standard short filter is # L10111
Thanks Ron !!
Just stole this off another forum hope it is correct.
Long Oil Filters that replace AC Delco PF47.
AC Delco - PF52
AMSOIL - EAO23
Baldwin - B35-S
GM - 25171377 (New#-19210286)
K&N - HP2001
Mobil1 - M1201
NAPA GOLD (WIX) – 1036
Purolator – 24011
WIX – 51036
i got some lists for ya...
PF47:
AC-DELCO PF37
AC-DELCO PF40
AC-DELCO PF47
AC-DELCO PF47E
ALLIANCE ABP/N10G-LF780
ALLOY ABH-3387
AMSOIL ASF29
AMSOIL EAO29
ATLAS G-72
ATLAS G-75
AUTO VALUE 1-3387A
AUTOEDGE AL3387A
AUTOPAR FE199
AUTOPAR FE289
AUTOPRO 2040
AUTOWIZE A14
AWARD AOF-112
BALDWIN B43-S
BECK/ARNLEY 041-8063
BECK/ARNLEY 041-8152
BIG A 92040
BOSCH 3331
BOSCH 72132
BRAVO B111
BUMPER TO BUMPER BBO-111
CAM2 C111
CANADIAN TIRE 17-1705-0
CANADIAN TIRE 17-1707-6
CARCARE IOF3387
CARQUEST 85040
CARQUEST B111
CASITE CF40
CASITE CF47
CATERPILLAR 3I-1110
CENEX CO445
CHAMP AR47
CHAMP PH47
CHAMPION OF02
CHRYSLER 3241398
CHRYSLER 8132313
CHRYSLER J3241398
CHRYSLER J8132313
CITGO C111
CO-OP VER-111
CRUISEMASTER 214
CRUISEMASTER 217
DAEWOO 93745067
DAEWOO 94797406
DAEWOO 96352845
DEFENSE DL4496
DELPHI FX1015
DELUXE WD-444
DELUXE WD-445
DEUTSCH D367
DONALDSON LFP550047
DONALDSON P550047
DYNALIFE CN-3387
ECONO LUBE L10111
EVERGARD E111
FACET 47
FIAAM FT4970
FILTERS INCORPORATED OF3387
FIRESTONE TF47
FIRESTONE TF-47
FLAG C-3387A
FLAG C-3980
FLEETGUARD LF42501
FLEETGUARD LF715
FLEETGUARD LF780
FLEETRITE LFR-8711
FLEETRITE LFR-8715
FLEETRITE LFR-8780
FRAM XG3387A
FRAM TG3387A
FRAM HM3387A
FRAM DG3387A
FRAM PH3387A
GENERAL MOTORS 25010792
GENERAL MOTORS 25014233
GENERAL MOTORS 25014693
GENERAL MOTORS 6439900
GENERAL MOTORS 6439901
GENERAL MOTORS 6439913
GENERAL MOTORS 6439929
GENERAL MOTORS 93156300
GENERAL MOTORS 93156310
GENERAL MOTORS 93156856
GENERAL MOTORS 93745067
GENERAL MOTORS 94797406
GENERAL MOTORS 96352845
GENERAL MOTORS 96395221
GENERAL MOTORS 96458873
GENERAL MOTORS 96879797
GONHER GP46
GONHER GP46M
GOODYEAR 222-4510
GOODYEAR 222-4514
GOODYEAR L47
GRAND PRIX PH47
GREASE MONKEY GM10111
GREASE MONKEY GM47
GROUP 7 V111
GULF GF-214
HASTINGS LF227
HASTINGS LF233
HASTINGS LF235
HAVOLINE T-26
HUTCHEN SF-111
IAPCO OF307
IAPCO OF47
ISUZU 8-25010-792-0
ISUZU 8-25014-693-0
ISUZU 8-92142-009-0
ISUZU 8-93156-298-0
ISUZU 8-93156-300-0
ISUZU 8-93156-998-0
ISUZU 8-97187-026-0
ITM 11-17200
ITM 111-7200
JIFFY LUBE HL3387A
JIFFY LUBE JL111
JIFFY LUBE L10111
JOHN DEERE TY9426
K & N HP-1001
K MART K-11
K MART MP-11
KENDALL K8
KERR-McGEE KM-47
KRALINATOR L147
LEE LF-111
LEE LF-40
LEE LF-40HP
LEE LF-47
LUBER-FINER PH47
LUCAS GIRLING F6542
LUCAS GIRLING F6605
MANN W 712/22
MANN & HUMMEL ML 1000
MANN & HUMMEL W712/12
MANN & HUMMEL W712/22
MARATHON MO3387A
MARATHON PH37
MARATHON-LETOURNEAU MO3387A
MARATHON-LETOURNEAU PH37
MASTER PARTS PH-37
MASTER PARTS PH-47
MECHANICS CIRCLE MOF 3387A
MICRO F-47A
MIGHTY M3387
MILEGUARD MO3387A
MINIT LUBE PH47
MITSUBISHI J8132313
MOBIL M1-101
MOBIL MO111
MOPAR L-320
MOPAR L-40
MOTOR TREND ML3387A
MOTORCRAFT FL 318
MOTORCRAFT FL 321
NAPA 1037
NAPA 1040
OE+ OF-552
PARTS MASTER 1-3387A
PARTS PLUS PH47
PENNZOIL PZ-9A
PERFORMAX PO-9A
PERFORMAX PO-9A
PHILLIPS 66 PO111
POWER FLO SL10111
PRECISION TUNE OF-132
PRO/GAUGE PGO-111
PROMOTIVE PH111
PRONTO PO-3387A
PRO-TEC 107
PUROLATOR L10111
PUROLATOR L10112
QUAKER STATE QS3387A
QUALITY QF47
ROCKHILL 61040
SAAB 45 02 696
SAFETY KLEEN 108
SEARS 45177
SEARS 45199
SECURITY SO-111
SELECT 500 L1040
SERIES 2 8107
SERVICE 1 OF111
SERVICE PRO SO3387A
SHELL SH26
SIEG OS3387A
SIERRA 18-7974
SILVERLINE 21040
STP S3387A
SUNOCO O-12
SUPERTECH ST3387A
SUZUKI 16510-84Z00
SUZUKI 16510-85Z20
TARGET SF111
TOYOTA 15615-U3160-71
TRUST PH47
UNOCAL PF47
VALUTEST 42007
VALUTEST V2040
VALVOLINE VO16
VERA 10-01691
VOLVO-PENTA MARINE 3827069
WALMI WS-3387
WARNER PH37
WARNER PH47
WESTERN AUTO 74-5802-9
WESTERN AUTO 74-5916-7
WIX 51040
WM. PENN WP-3387
XSV OP-111
PF52:
AC-DELCO PF52
AC-DELCO PF52E
ALLIANCE ABP/N10G-LF782
AM GENERAL 06004104
AMSOIL ASF23
AMSOIL EAO23
AQUA POWER 6004
ATLAS G-77
AUTO VALUE 1-3535
AUTOEDGE AL3980
AUTOPAR FE204
AUTOPRO 2036
AUTOWIZE A15
AWARD AOF-173
BALDWIN B35-S
BIG A 92036
BOSCH 3430
BOSCH 72210
BRAVO B173
CAM2 C4011
CANADIAN TIRE 17-1710-6
CANADIAN TIRE 17-1712-2
CARCARE IOF3535
CARCARE IOF3980
CARQUEST 85036
CARQUEST B4011
CASITE CF51
CASITE CF52
CATERPILLAR 3I-1114
CENEX CO447A
CHAMP PH51A
CHAMPION OF08
CHAMPION OF32
CHRYSLER L-319
CITGO C4011
CRUISEMASTER 218
DEFENSE DL4814
DELPHI FX1016
DEUTSCH D487
DONALDSON LFP550051
DONALDSON P550051
DYNALIFE CN-3535
ECONO LUBE L24011
EVERGARD E4011
FACET 51
FILTERS INCORPORATED OF3535
FILTERS INCORPORATED OF3980
FIRESTONE TF52
FLAG C-3535
FLAG C-3980
FLEETGUARD LF3554
FLEETGUARD LF42503
FLEETGUARD LF782
FLEETRITE LFR-83486
FLEETRITE LFR-8782
FRAM XG3980
FRAM TG3980
FRAM HM3980
FRAM DG3980
FRAM PH3980
GENERAL MOTORS 12555891
GENERAL MOTORS 25010908
GENERAL MOTORS 25012760
GENERAL MOTORS 25160560
GENERAL MOTORS 25171377
GENERAL MOTORS 25325403
GONHER GP3980
GONHER GP48
GOODYEAR 222-4516
GOODYEAR L51
GOODYEAR L52
GRAND PRIX PH51A
GREASE MONKEY GM24011
GREASE MONKEY GM51
GREASE MONKEY GM52
GROUP 7 V173
GROUP 7 V4011
HASTINGS LF234
HASTINGS LF393
HAVOLINE T-27
HUTCHEN SF-173
HYSTER 1320000
HYSTER 375588
ISUZU 8-25171-377-0
JIFFY LUBE HL3980
JIFFY LUBE JL173
JIFFY LUBE JL4011
JIFFY LUBE L20173
JIFFY LUBE L24011
JOHN DEERE TY15135
K & N HP-2001
K MART K-12
K MART MP-12
K MART MP-42
KENDALL K10
KENDALL K25
KRALINATOR L197
KRALINATOR L297
LEE LF-51
LEE LF-51A
LEE LF-51AHP
LEE LF-51HP
LUBER-FINER PH51A
MANN & HUMMEL ML 1007
MANN & HUMMEL W713/18
MANN & HUMMEL W718/3
MARATHON MO51
MARATHON-LETOURNEAU MO51
MASTER PARTS PH-51
MASTER PARTS PH-51A
MECHANICS CIRCLE MOF 3535
MECHANICS CIRCLE MOF 3980
MERCRUISER 35-802884Q
MERCRUISER 35-802884T
MERCRUISER 35-883702Q
MERCRUISER 41815
MICRO F-173
MIGHTY M3980
MILEGUARD MO3980
MILEGUARD MO3980
MINIT LUBE PH51
MOBIL M1-201
MOBIL MO4011
MOTOR TREND ML3980
MOTORCRAFT FL 402
NAPA 1036
OMC 173834
OMC 502903
PARTS MASTER 1-3535
PARTS MASTER 1-3980
PARTS PLUS PH51A
PENNZOIL PZ-29
PERFORMAX PO-29
PERFORMAX PO-29
PHILLIPS 66 PO4011
POWER FLO SL24011
PRECISION TUNE OF-144
PRECISION TUNE OF-52
PRO/GAUGE PGO-4011
PROMOTIVE PH4011
PRONTO PG-3980
PRONTO PO-3535
PRONTO PO-3980
PRO-TEC 120
PUROLATOR L20173
PUROLATOR L24011
QUAKER STATE QS3980
QUALITY QF51
ROCKHILL 61036
SAFETY KLEEN 110
SEARS 45180
SEARS 45203
SECURITY SO-173
SELECT 500 L1036
SERVICE 1 OF173
SERVICE PRO SO3980
SHELL SH27
SIEG OS3535
SIERRA 18-7879
SILVERLINE 21036
STP S3980
SUNOCO O-17
SUNOCO O-29
SUPERTECH ST3980
TARGET SF51
TARGET SF51A
TRUST PH51A
UNOCAL PF51
VALUTEST 42051
VALUTEST V2036
VALVOLINE VO55
VOLVO 841750
VOLVO 841750-3
WALMI WS-3535
WALMI WS-3980
WARNER PH51
WARNER PH51A
WESTERN AUTO 74-5918-3
WIX 51036
WIX 51190
WORKHORSE CUSTOM CHASSIS W8800466
XSV OP-173
YAMAHA YSC-16231-20-0C
YAMAHA YSC-16231-20-OC
AC Delco - PF52
AMSOIL - EAO23
Baldwin - B35-S
K&N - HP2001
Mobil1 - M1201
Purolator – 24011
WIX – 51036
Thanks Ron ! That was really cool , all of us can use these part numbers .
PF47:
AC-DELCO PF37
AC-DELCO PF40
AC-DELCO PF47
AC-DELCO PF47E
ALLOY ABH-3387
AMSOIL ASF29
AMSOIL EAO29
ATLAS G-72
ATLAS G-75
AUTO VALUE 1-3387A
AUTOEDGE AL3387A
AUTOPAR FE199
AUTOPAR FE289
AUTOPRO 2040
AUTOWIZE A14
AWARD AOF-112
BALDWIN B43-S
BIG A 92040
BOSCH 3331
BOSCH 72132
BRAVO B111
CAM2 C111
CARCARE IOF3387
CARQUEST 85040
CARQUEST B111
CASITE CF40
CASITE CF47
CATERPILLAR 3I-1110
CENEX CO445
CHAMP AR47
CHAMP PH47
CHAMPION OF02
CHRYSLER 3241398
CHRYSLER 8132313
CHRYSLER J3241398
CHRYSLER J8132313
CITGO C111
CO-OP VER-111
CRUISEMASTER 214
CRUISEMASTER 217
DAEWOO 93745067
DAEWOO 94797406
DAEWOO 96352845
DEFENSE DL4496
DELPHI FX1015
DELUXE WD-444
DELUXE WD-445
DEUTSCH D367
DONALDSON LFP550047
DONALDSON P550047
DYNALIFE CN-3387
ECONO LUBE L10111
EVERGARD E111
FACET 47
FIAAM FT4970
FIRESTONE TF47
FIRESTONE TF-47
FLAG C-3387A
FLAG C-3980
FLEETGUARD LF42501
FLEETGUARD LF715
FLEETGUARD LF780
FLEETRITE LFR-8711
FLEETRITE LFR-8715
FLEETRITE LFR-8780
FRAM XG3387A
FRAM TG3387A
FRAM HM3387A
FRAM DG3387A
FRAM PH3387A
GONHER GP46
GONHER GP46M
GOODYEAR 222-4510
GOODYEAR 222-4514
GOODYEAR L47
GRAND PRIX PH47
GREASE MONKEY GM47
GROUP 7 V111
GULF GF-214
HASTINGS LF227
HASTINGS LF233
HASTINGS LF235
HAVOLINE T-26
HUTCHEN SF-111
IAPCO OF307
IAPCO OF47
ISUZU 8-25010-792-0
ISUZU 8-25014-693-0
ISUZU 8-92142-009-0
ISUZU 8-93156-298-0
ISUZU 8-93156-300-0
ISUZU 8-93156-998-0
ISUZU 8-97187-026-0
ITM 11-17200
ITM 111-7200
JIFFY LUBE HL3387A
JIFFY LUBE JL111
JIFFY LUBE L10111
JOHN DEERE TY9426
K & N HP-1001
K MART K-11
K MART MP-11
KENDALL K8
KERR-McGEE KM-47
KRALINATOR L147
LEE LF-111
LEE LF-40
LEE LF-40HP
LEE LF-47
LUBER-FINER PH47
LUCAS GIRLING F6542
LUCAS GIRLING F6605
MANN W 712/22
MARATHON MO3387A
MARATHON PH37
MASTER PARTS PH-37
MASTER PARTS PH-47
MICRO F-47A
MIGHTY M3387
MILEGUARD MO3387A
MINIT LUBE PH47
MITSUBISHI J8132313
MOBIL M1-101
MOBIL MO111
MOPAR L-320
MOPAR L-40
MOTOR TREND ML3387A
MOTORCRAFT FL 318
MOTORCRAFT FL 321
NAPA 1037
NAPA 1040
OE+ OF-552
PARTS PLUS PH47
PENNZOIL PZ-9A
PERFORMAX PO-9A
PERFORMAX PO-9A
PHILLIPS 66 PO111
POWER FLO SL10111
PRO/GAUGE PGO-111
PROMOTIVE PH111
PRONTO PO-3387A
PRO-TEC 107
PUROLATOR L10111
PUROLATOR L10112
QUALITY QF47
ROCKHILL 61040
SAAB 45 02 696
SAFETY KLEEN 108
SEARS 45177
SEARS 45199
SECURITY SO-111
SELECT 500 L1040
SERIES 2 8107
SERVICE 1 OF111
SERVICE PRO SO3387A
SHELL SH26
SIEG OS3387A
SIERRA 18-7974
SILVERLINE 21040
STP S3387A
SUNOCO O-12
SUPERTECH ST3387A
SUZUKI 16510-84Z00
SUZUKI 16510-85Z20
TARGET SF111
TRUST PH47
UNOCAL PF47
VALUTEST 42007
VALUTEST V2040
VALVOLINE VO16
VERA 10-01691
WALMI WS-3387
WARNER PH37
WARNER PH47
WIX 51040
WM. PENN WP-3387
XSV OP-111
PF52:
AC-DELCO PF52
AC-DELCO PF52E
AM GENERAL 06004104
AMSOIL ASF23
AMSOIL EAO23
AQUA POWER 6004
ATLAS G-77
AUTO VALUE 1-3535
AUTOEDGE AL3980
AUTOPAR FE204
AUTOPRO 2036
AUTOWIZE A15
AWARD AOF-173
BALDWIN B35-S
BIG A 92036
BOSCH 3430
BOSCH 72210
BRAVO B173
CAM2 C4011
CARCARE IOF3535
CARCARE IOF3980
CARQUEST 85036
CARQUEST B4011
CASITE CF51
CASITE CF52
CATERPILLAR 3I-1114
CENEX CO447A
CHAMP PH51A
CHAMPION OF08
CHAMPION OF32
CHRYSLER L-319
CITGO C4011
CRUISEMASTER 218
DEFENSE DL4814
DELPHI FX1016
DEUTSCH D487
DONALDSON LFP550051
DONALDSON P550051
DYNALIFE CN-3535
ECONO LUBE L24011
EVERGARD E4011
FACET 51
FIRESTONE TF52
FLAG C-3535
FLAG C-3980
FLEETGUARD LF3554
FLEETGUARD LF42503
FLEETGUARD LF782
FLEETRITE LFR-83486
FLEETRITE LFR-8782
FRAM XG3980
FRAM TG3980
FRAM HM3980
FRAM DG3980
FRAM PH3980
GONHER GP3980
GONHER GP48
GOODYEAR 222-4516
GOODYEAR L51
GOODYEAR L52
GRAND PRIX PH51A
GREASE MONKEY GM51
GREASE MONKEY GM52
GROUP 7 V173
GROUP 7 V4011
HASTINGS LF234
HASTINGS LF393
HAVOLINE T-27
HUTCHEN SF-173
HYSTER 1320000
HYSTER 375588
ISUZU 8-25171-377-0
JIFFY LUBE HL3980
JIFFY LUBE JL173
JIFFY LUBE JL4011
JIFFY LUBE L20173
JIFFY LUBE L24011
JOHN DEERE TY15135
K & N HP-2001
K MART K-12
K MART MP-12
K MART MP-42
KENDALL K10
KENDALL K25
KRALINATOR L197
KRALINATOR L297
LEE LF-51
LEE LF-51A
LEE LF-51AHP
LEE LF-51HP
LUBER-FINER PH51A
MARATHON MO51
MASTER PARTS PH-51
MASTER PARTS PH-51A
MERCRUISER 41815
MICRO F-173
MIGHTY M3980
MILEGUARD MO3980
MILEGUARD MO3980
MINIT LUBE PH51
MOBIL M1-201
MOBIL MO4011
MOTOR TREND ML3980
MOTORCRAFT FL 402
NAPA 1036
OMC 173834
OMC 502903
PARTS MASTER 1-3535
PARTS MASTER 1-3980
PARTS PLUS PH51A
PENNZOIL PZ-29
PERFORMAX PO-29
PERFORMAX PO-29
PHILLIPS 66 PO4011
POWER FLO SL24011
PRO/GAUGE PGO-4011
PROMOTIVE PH4011
PRONTO PG-3980
PRONTO PO-3535
PRONTO PO-3980
PRO-TEC 120
PUROLATOR L20173
PUROLATOR L24011
QUAKER STATE QS3980
QUALITY QF51
ROCKHILL 61036
SAFETY KLEEN 110
SEARS 45180
SEARS 45203
SECURITY SO-173
SELECT 500 L1036
SERVICE 1 OF173
SERVICE PRO SO3980
SHELL SH27
SIEG OS3535
SIERRA 18-7879
SILVERLINE 21036
STP S3980
SUNOCO O-17
SUNOCO O-29
SUPERTECH ST3980
TARGET SF51
TARGET SF51A
TRUST PH51A
UNOCAL PF51
VALUTEST 42051
VALUTEST V2036
VALVOLINE VO55
VOLVO 841750
VOLVO 841750-3
WALMI WS-3535
WALMI WS-3980
WARNER PH51
WARNER PH51A
WIX 51036
WIX 51190
XSV OP-173
Thanks Rob. I am sure that will help someone,
I disapprove of that list. It does not list the Auto Extra brand number.
I no longer haz :(.
Edit: Post number 1,000 FTW.
Edited by WhatTheFehl
  • 1 year later...
I hate when others bump old threads....but I think this one is still relevant. Besides, i was in basic when this thread came about....:lol:
I was searching 51036 for Wix filters and this thread was close to the top.
