OldsCrazy Posted August 28, 2010 Report Posted August 28, 2010 It seems on a hot day my 95 Cutlass Convert will shift into 4th ok then once I sit in traffic and then get going again the trans will shift into 4th but then I am stuck in 3rd until I shut the car off and back on. That may work for a mile or 2 then it will pop out again. Once it sets it is ok again but if it heats up a little it will pop out of 4th agian. It never happens in the spring, fall or winter so it must be a heat thing. Any ideas besides a transmission rebuild? Thanks, OldsCrazy Quote
Night Fury Posted August 28, 2010 Report Posted August 28, 2010 ^^^^Most EPIC use of that pic yet!!!!! LOLLOLOLOOLOLOLOOL Quote
Highmilagecutlass Posted August 28, 2010 Report Posted August 28, 2010 Hey Old Crazy Do a pan drop and do visual inspection, install a quality trans filter and some DEX VI, I would guess 7 quarts. If you still have problems. replace the radiator or add a trans cooler. Good luck. P.S DONT EVER ADD LUCAS to your transmission, the problem you are having is typical Quote
OldsCrazy Posted August 28, 2010 Author Report Posted August 28, 2010 I will give that a try, thank you for the help. OldsCrazy Quote
Highmilagecutlass Posted August 28, 2010 Report Posted August 28, 2010 I will give that a try, thank you for the help. OldsCrazy It's no problem I also had a similar problem with my transmission in my 1994 Oldsmobile Cutlass Supreme 4t60e Just dont settle for a flush/fluid exchange at a quick lube, you must remove the pan. Good luck:) Quote
