webxfx Posted August 24, 2010 Report Posted August 24, 2010 Its in a 96 GP GT with the LQ1, so I know it won't be easy... Do I need to drop the rear sub-frame? or is there an easier way to get at it? I'm almost sure its the hi-pres line Quote
White93z34 Posted August 24, 2010 Report Posted August 24, 2010 ugh screw that thing. I've done it and its not fun. I ended up dropping the rear of the subframe and unbolting the column from the rack. In the end I believe I cut the hose off at the rack and turned the fitting out with a socket. Quote
