stockgp Posted August 22, 2010 Report Posted August 22, 2010 i can't find my haynes manual, and i need the torque specs for the rocker studs, rocker nuts, and the upper and lower intake manifold bolts Quote
mfewtrail Posted August 23, 2010 Report Posted August 23, 2010 1990 3.1: Lower intake manifold bolts - tighten to 15ft-lbs in sequence, then tighten them to 24 ft-lbs. Upper intake manifold - 16 ft-lbs, there is no sequence for these. Rocker arm studs - 47 ft-lbs Rocker arm nuts - 18 ft-lbs Rocker cover/valve cover bolts(just in case you want to torque those too) 89in-lbs(note this is in inch-lbs!) Here's a picture for the lower intake manifold torque sequence: http://home.windstream.net/mfewtrail/images/intman.jpg Quote
stockgp Posted August 23, 2010 Author Report Posted August 23, 2010 thanks. bonus thanks for the pic.:dance:u Quote
