I busted my 6-point 15mm socket with my breaker bar today on the first subframe bolt I tried. What do you guys use when you come across seized up subframe bolts. I really don't wanna screw these up.
I use my impact gun..
other than that, get a quality socket and a bigger breaker bar.
your subframe bolts are 15mm?? Musta been an early gen 1 thing. As I know my 95 and 96 cutlasses are 18mm
I just bought a 15mm impact socket from advance auto today for something like $6. If you can break an impact socket...damn.
88-93 use 15mm
94+ use 18mm
94 lumina?... uncertain...
you should try to get access to the back side of the bolt and spray it with PB Blaster. Is it the front or rear?
mapp gas and spray it down with some of that pb blaster crap..
The Impact socket with the big breaker bar worked well, thanks. I tried using an impact on all four to start, and I got two that way, but the driver's side was really seized, at one point I was sure I had sheared them off, but I got really lucky.
there is a hole on the outer side of the body structural rail which you can see and spray the top of the bolt from...
You're lucky they came out and didn't break the welded nut off the back. Then you REALLY have a problem.
Thats what happened to me a few months back. I ordered a new nut from the dealer and just recently got mine replaced. I hope to never fo that again! lol Mine was the driver rear and I cut through the floor from inside and replaced it.
