meltboy1 Posted August 19, 2010 Report Posted August 19, 2010 I was looking at this thread, http://www.w-body.com/showthread.php/33674-clutch-pedal-removal but never found the answer, I am stuck trying to figure out how to get the clutch pedal out, I got almost everything else out, but can't get this, can someone help me out please. Quote
meltboy1 Posted August 20, 2010 Author Report Posted August 20, 2010 36 people checkin thread and nodoby knows an easy way to get this thing out, I don't want to have to rip the whole dash apart, but I can't see a way to get on the bolt. Quote
Crazy K Posted August 20, 2010 Report Posted August 20, 2010 It is held on with a nut and bolt. iirc is is either 15mm both, or 13 and 15. read this thread: http://www.w-body.com/showthread.php/22155-My-GTP-1994-manual-swap..-more-pics...-%28warning-56K%29/page3 you can se images of what you are looking for. I have removes the pedal, without removing the bracket, but I think you need a wrench to hols the bolt... Quote
meltboy1 Posted August 20, 2010 Author Report Posted August 20, 2010 omg that looks tough... I see myself getting it out, but I think when it goes in the TGP i'm gona have to remove the dash and steering to get it back in there... >< Glad this car is going to the yard, so I don't have to be gentle getting it out, thanks for that link Quote
jimmyfloyd Posted August 20, 2010 Report Posted August 20, 2010 yeah. Getting the whole brace out was a royal pain in the arse. And I did it in a junkyard car, so I didn't worry about breaking anything I didn't need. Took me a couple hours to figure it out. Quote
Crazy K Posted August 20, 2010 Report Posted August 20, 2010 I've pulled that brace on maybe 2 dozen cars. not THAT bad... the worst was the 96 buick I helped Bob pull a dash from, cause the top bolt was in backwards, which means the bolt could not be pushed out as it contacts the firewall. If you are already have the dash pulled, you have 2 nuts and 2 bolts in the square holes at the top, 2 bolts on the left, 1 on the right, and then the bastard is the final bolt that goes through the brake pedal at the top. For the top bolt you have to hold the nut which should be on the left with one ratchet and turn the bolt head on the right with another ratchet. othersiw disconnect all wires and the brake pedal and clutch pedal. out is comes. Quote
meltboy1 Posted August 20, 2010 Author Report Posted August 20, 2010 ok ya, I think with as bad as my back is though, I can't be underneath the dash like that, I might have to remove the whole dash and do it that way... thanks for the info. Quote
Addicted2bass Posted August 26, 2010 Report Posted August 26, 2010 One of the previous owners of my TGP started a 5-speed swap and installing the clutch pedal was as far as they got! Quote
meltboy1 Posted September 5, 2010 Author Report Posted September 5, 2010 lol well I got the damn thing out finally, and I figure when I do the swap on my tgp, I'll try to put that in first since thats the biggest pain in the butt..lol Quote
gpchris Posted September 5, 2010 Report Posted September 5, 2010 What are you trying to do? You you just want to remove the petal or are you removing the bracket to do a 5spd swap on a different car? Quote
