System install With pictures!
Every time I do something, People want pictures, It tells the story. So First things first, Im installing everything But the sub and Sub amp (still working on getting an amp)
Lets get started everything laying on the table
Now yes its Going to be Dirty! ( I have not cleaned the car since I got it in april (hey I have only put 900 miles on it! LOL)
Removing the back seat
Just showing you how dirty it is! LOL
Back seat fully removed!
New Vs old
Break time!
Ok! Now that were back, Let get the power wire ran,
Fuse on top is the fuse that my Monster kit came with, No thanks! Ill still with Nice fuse blocks!
And again
This is the best place to run your power wire! Firewall! On the passenger side floor!
In this picture I know it looks like its coming from the door jam, But its not, the wire is just sitting over it so its out of my way!
Another pic of the fire wall!
Just hooking up the remote wire, and Composite cables
All the wires in the back ran under the carpet and back seat!
Here is where I mounted the door speaker amp
open
Dirt bike or car? HUMMM
Hooking up the rear speakers, running speaker wireing!
Rear speakers in
Front door panel removed
Running speaker wire threw the rubber boot into the door
And put back together!
All the wires ran
Going back in
Well that’s all for now, Its deep cleaning time! (its done my cam died LOL)
What do you mean by keep? Just showing the difference.
I like the extra time you're taking for a install that will look clean when finished...
Looks like you used 8 gauge? If you add a sub amp you may want to run a second 8 gauge line for the sub amp, two amps on 8 usually isn't that great of a plan. way to keep it clean though. Now get that poor car detailed!
Edited by GTP091
Its been cleaned since, Im going to run 0 Gauge for my 1000 Kicker and 2 12 l7's
  • 3 weeks later...
  • 3 years later...
Do you get much alternator whine? I have a 4-channel in my 1998 GTP and I have tons of it (RCA's ran on opposite side of power). I've done the big 3 upgrade and I have the paint ground down for all the ground connections.
