91eurocpe Posted August 12, 2010 Report Posted August 12, 2010 I have a 1991 Lumina EuroCoupe the left door when you open and close it has a creak sound to i i tried to lube the hinges but that didnt work any suggestions Quote
WhatTheFehl Posted August 12, 2010 Report Posted August 12, 2010 Give it time. Eventually the metal will snap, and no more noise. Unfortunately the door won't keep itself open anymore. This happened to my passenger door. I greased the heck out of everything and there was no way that I found to stop it. Quote
Addicted to eaton Posted August 12, 2010 Report Posted August 12, 2010 Use a white grease, something Thick. Quote
ruktosk Posted August 12, 2010 Report Posted August 12, 2010 My anteater had a similar problem recently. Bought some lithium grease from the auto parts store. A few squirts and moving the hinge back and forth a few times took care of it. Quote
WhatTheFehl Posted August 12, 2010 Report Posted August 12, 2010 My anteater had a similar problem recently. Bought some lithium grease from the auto parts store. A few squirts and moving the hinge back and forth a few times took care of it. I freakin hosed mine in sprayable red grease. Repeatedly. Everything I could see got coated. Didn't help. Quote
Crazy K Posted August 12, 2010 Report Posted August 12, 2010 did you grease the door holder thingy? you know, the part that goes "Click Click clunk" I've learned that these parts need reinforcement, BTW.... the metal of the inndr door skin where they mount is too thin... Add a 3/16th" by 1" washer works great to reinforce the door skin, or if the skin has filed, to substitute for it. Quote
WhatTheFehl Posted August 12, 2010 Report Posted August 12, 2010 Duh. That's what broke eventually. Every car I can remember my family owning... spraying the door holder and the hinge with red grease made it quiet and smooth as butter... not mine. Quote
Crazy K Posted August 12, 2010 Report Posted August 12, 2010 Did you want to try and fix it???? I just told you enough for you to figure out the rest.... but here's a few more clues: door holders are the same left and right across all the GEN 1 the platforms.... and they interchange as follows. 2 door fits only 2 door. 4 door front fits only 4 door front. 4 door rear fits only 4 door rear. So next time you are at the j/y, find a donor you like and pull the clicker from the door... but preferably a right door, as they are less worn. Go to Lowes and find the washers I mention (4 for $1, iirc) and install. Quote
mra32 Posted August 12, 2010 Report Posted August 12, 2010 (edited) door holders are the same left and right across all the GEN 1 the platforms.... and they interchange as follows. 2 door fits only 2 door. 4 door front fits only 4 door front. 4 door rear fits only 4 door rear. So next time you are at the j/y, find a donor you like and pull the clicker from the door... but preferably a right door, as they are less worn. Go to Lowes and find the washers I mention (4 for $1, iirc) and install. WIN! Thats how i fixed mine. I think ken (maybe chris) gave me the same advice to help me do this. It was also one of my favorite repairs...simple and has a profound effect on the perceived crappiness of the car. I replaced mine with a Maui blue (or whatever bright blue the sedans had) so it almost blends in. Edited August 12, 2010 by mra32 Quote
mra32 Posted August 12, 2010 Report Posted August 12, 2010 door holders are the same left and right across all the GEN 1 the platforms.... and they interchange as follows. 2 door fits only 2 door. 4 door front fits only 4 door front. 4 door rear fits only 4 door rear. So next time you are at the j/y, find a donor you like and pull the clicker from the door... but preferably a right door, as they are less worn. Go to Lowes and find the washers I mention (4 for $1, iirc) and install. WIN! Thats how i fixed mine. I think ken (maybe chris) gave me the same advice to help me do this. It was also one of my favorite repairs...simple and has a profound effect on the perceived crappiness of the car. I replaced mine with a Maui blue (or whatever bright blue the sedans had) so it almost blends in. DOUBLE POST FTMFW Quote
91eurocpe Posted August 13, 2010 Author Report Posted August 13, 2010 Thanks for all your help guys i appreciate it i will fix this weekend Quote
