DavidHowell3633 Posted August 11, 2010 Report Posted August 11, 2010 My son's car has been parked since May since he got a "new ride". It's been too hot to tinker with it and get it sellable. I was going to pull it into the garage today to give us more room in the driveway. Lo and behold, putting the trans into any gear does absolutely nothing. Just prior to May time frame, my son reported that the trans did not want to shift out of 1 or 2 at times. When I drove it, it seemed ok. The oil level is good and fluid appears to retain its color. It has always run with a cooler as long as we've owned the car. In fact, I thought the trans was the best thing about the car- until today. I looked at the vacuum connections and tested the easier ones and they're ok. My assumption is that seals have shrunk and pumps can't pump. I have been impressed with GM's Transmission Sealer and Conditioner since it fixed my lag times for reverse kicking in with my 94 CS convertible. I am thinking of pouring some in and running it in gear while idling and crossing my fingers. Any suggestions as to where to look or what might be wrong? Thanks, David Quote
tornado_735 Posted August 11, 2010 Report Posted August 11, 2010 I'd say drop the pan and do a fluid and filter change. It's not too hard of a job at all, and is more messy than anything. Quote
DavidHowell3633 Posted August 11, 2010 Author Report Posted August 11, 2010 Thanks. Changed fluid and filter about 15,000 ago. Quote
tornado_735 Posted August 11, 2010 Report Posted August 11, 2010 Thanks. Changed fluid and filter about 15,000 ago. Well shit. Some people would advocate doing it again since a pan drop only nets about 60% of the fluid, but I'm not so sure. Quote
AL Posted August 11, 2010 Report Posted August 11, 2010 If you are going to let it idle in gear, PLEASE make sure someone is in it and can hit the brakes if necessary... Good luck! Quote
birdman Posted August 11, 2010 Report Posted August 11, 2010 real men use the parking brake and dont worry about it. Quote
AL Posted August 11, 2010 Report Posted August 11, 2010 I havent known many first gens with a working parking brake... I know I havent ever had one Quote
WhatTheFehl Posted August 12, 2010 Report Posted August 12, 2010 Mine works too... very well actually... Find a first gen in PA. It has to work to pass inspection. Quote
DavidHowell3633 Posted August 12, 2010 Author Report Posted August 12, 2010 The parking brake works fine as does everything else, EXCEPT the transmission. Thanks everyone for insight into the parking brake issue. I learned something new. Quote
Crazy K Posted August 12, 2010 Report Posted August 12, 2010 jack up and raise one of the front tires. place car in gear. no load may allow the transmission to kick and engage... and once lowered it may move under it's own power. REALLY. additional thought: fluid level, check the level with the car off(assuming it hasn't run all day). it should be high. start car. if the fluid level did not drop, there is no pumping going on, as parts of the transmission will fill with fluid only with the engine running. Quote
DavidHowell3633 Posted August 12, 2010 Author Report Posted August 12, 2010 Once again, you offer real help. Thanks! Really. Quote
BXX Posted August 13, 2010 Report Posted August 13, 2010 Unplug the trans connector and plug it back on. Loose connection there will piss the trans off pretty bad. Quote
DavidHowell3633 Posted August 13, 2010 Author Report Posted August 13, 2010 Will try that first. Thanks. Can't try until rains stops. Quote
DavidHowell3633 Posted August 15, 2010 Author Report Posted August 15, 2010 The car is in the garage under its own power. Hiking a leg and putting it in gear actually worked. Who would have thought? Crazy K. Thanks. Quote
