91eurocpe Posted August 11, 2010 Report Posted August 11, 2010 I have a 1991 Lumina euro coupe will z-34 dual exhaust fit right on please let me know thanks Quote
jman093 Posted August 12, 2010 Report Posted August 12, 2010 I think you'll need a Z34 rear bumber with the spaces cutout for the dual exhausts. Quote
91eurocpe Posted August 13, 2010 Author Report Posted August 13, 2010 i thought the z34 was a body kit around it is the car the same underneath Quote
intern8tion9l Posted August 13, 2010 Report Posted August 13, 2010 I think you'll need a Z34 rear bumber bumPer, for the love of god i think you.d be able to pick up any w-body dual exhaust setup and make it work for your application Quote
digitaloutsider Posted August 13, 2010 Report Posted August 13, 2010 It fits right on, no modification needed. Quote
White93z34 Posted August 13, 2010 Report Posted August 13, 2010 Not only does it fit good but it looks good. on a stock single exhaust 3.1 car you will probably have to bolt up the left side hanger brackets, and you may need a exhaust shop to weld it up near the cat for it to fit proper but other then that its bolt on. Quote
91eurocpe Posted August 13, 2010 Author Report Posted August 13, 2010 ok thanks for all the information one thing where can i get the exhaust tips Quote
White93z34 Posted August 13, 2010 Report Posted August 13, 2010 Junkyard z34? do you want to put the whole catback on or are you getting a custom exhaust fabbed up? Quote
91eurocpe Posted August 13, 2010 Author Report Posted August 13, 2010 i would like to buy all the parts to do it the y pipe and mufflers and maybe us different tips Quote
pontiacmaniac94 Posted August 13, 2010 Report Posted August 13, 2010 You can get tips from autozone/o'reily's/napa/whatever. or you could them used off basically any car at the yard. some of the tips will come off pretty easily with a socket and some muscle, while others willl take basically forever, and you would have to cut them off, just depends on how motiviated you are to get them. Quote
carkhz316 Posted August 13, 2010 Report Posted August 13, 2010 IIRC stock Z34 tips are welded to the muffler. X2 on getting any of your choice from a parts store Quote
rich_e777 Posted August 28, 2010 Report Posted August 28, 2010 bumPer, for the love of god i think you.d be able to pick up any w-body dual exhaust setup and make it work for your application Will that possibly work with a `94 Cutlass with a 3100? Quote
intern8tion9l Posted August 28, 2010 Report Posted August 28, 2010 it will work on any w. as stated, you will need the driver's side rear hanger Quote
1979lee Posted August 30, 2010 Report Posted August 30, 2010 i thought about doing this too my 98 3.1 lumina, but i have too ask IS it worth it? will there be better performance/mpg? i know where i can get the parts cheap used but cheap. and its damend easy job too do, just unbolt 2 bolts/nuts and un hook the hangers at the back and bam duel outlet pipes. Quote
94 olds vert Posted August 30, 2010 Report Posted August 30, 2010 i thought about doing this too my 98 3.1 lumina, but i have too ask IS it worth it?will there be better performance/mpg? i know where i can get the parts cheap used but cheap. and its damend easy job too do, just unbolt 2 bolts/nuts and un hook the hangers at the back and bam duel outlet pipes. You will see no gains in performance/mpg. It's mostly for looks. And it will up the cool factor for your lumina. Quote
