Lumina Z-34 recalls??
This:
TSB Number = 93C19
Issue Date = JUL 93
TSB Title = Campaign - Automatic Transaxle Channel Plate Distorted
Was the only one for 1993.
This:
TSB Number = 93C19
Issue Date = JUL 93
o.O
I did a search of the TSB's at the GM eSI site and got the following results for 1993. Not all may apply to the Z34, and some apply to all GM vehicles including the Z34.
#33-12-26 RETROFITTING R-12 VEHICLES TO R-134A (INFORMATIONAL) - (Dec 22, 1993)
#37-71-38A SECOND GEAR VIBRATION AT 3000- 5000 RPM (INST. SHAFT PACKAGE) - (Oct 26, 1993)
#31-90-03 SUPPLEMENTAL INFLATABLE RESTRAINT (SIR) PASSENGER SIDE - (Oct 18, 1993)
#37-71-36 INTERMITTENT OR NO TCC APPLY (REPL. TRANSAXLE WIRE HARNESS) - (Oct 13, 1993)
#23-60-07 OCCASIONAL ENGINE STALL (VERIFY CRANKSHAFT END PLAY) - (Oct 6, 1993)
#37-71-34 HARSH CLUTCH ENGAGEMENT 'GARAGE SHIFT' - (Sep 30, 1993)
#37-65-10 SHORT OPERATION OF MALFUNCTION INDICATOR LAMP (MIL) - (Sep 16, 1993)
#33-32-10A STEERING COLUMN POPPING NOISE (REPL. UPPER BRG. INNER SEAT) - (Sep 9, 1993)
#33-65-06 ENG. STALL, LONG CRANKS/IDLE/ DECEL SURGE (DIAG. REPL. PROM) - (Aug 31, 1993)
#23-66-02A SQUEAK FROM FRONT OF VEHICLE REPLACE EXHAUST PIPE SPRINGS - (Aug 27, 1993)
#93-169-3E TIRES SLIPPING ON WHEELS USE PROPER TIRE MOUNTING PROC - (Aug 1, 1993)
#3N20 TRANSAXLE DISTRESS DUE TO DISTORTED CHANNEL PLATE ASSY. - (Aug 1, 1993)
#93-3E-103 TIRES SLIPPING ON WHEELS USE PROPER TIRE MOUNTING PROC - (Aug 1, 1993)
#93-197B-3E INFO. ON COSMETIC DAMAGE TO ALUMINUM WHEELS DURING BALANC. - (Aug 1, 1993)
#93-3E-104 INFO. ON COSMETIC DAMAGE TO ALUMINUM WHEELS DURING BALANC. - (Aug 1, 1993)
#93-272-7A TRANSAXLE BRG. WHINE AUDIBLE IN 1ST,2ND, & 3RD GEAR - (Jul 21, 1993)
#93-7A-151 TRANSAXLE BRG. WHINE AUDIBLE IN 1ST,2ND, & 3RD GEAR - (Jul 21, 1993)
#93-263-3E LEAKING CAST ALUMINUM WHEELS (REPAIR WITH ADHESIVE SEALANT) - (Jul 1, 1993)
#93-3E-106 LEAKING CAST ALUMINUM WHEELS (REPAIR WITH ADHESIVE SEALANT) - (Jul 1, 1993)
#93-53A-7A TRANSAXLE FLUID LEAK AT CON. (INSTALL NEW HELIX CON. SEAL) - (Jul 1, 1993)
#33-10-30 SHOULDER BELT CONTACTS NECK OF DRIVER & FRONT PASS. SEAT - (Jun 14, 1993)
#93-223-7A INFO. ON SERVICING VEHICLE WITH CONTAMINATED TRANS. FLUID - (May 19, 1993)
#93-7A-142 INFO. ON SERVICING VEHICLE WITH CONTAMINATED TRANS. FLUID - (May 19, 1993)
#93-8A-632 NEW TOOL FOR OPTICAL REDUNDANT STEERING WHEEL CONTROL SYSTEM - (Apr 30, 1993)
#93-10-194 BINDING/STICKING LOCK CYLINDER RECOMMENDED LUBRICATIONS - (Apr 30, 1993)
#93-193-7A INFO. ON NEW 3RD CLUTCH SPRAG ASSEMBLY - (Apr 29, 1993)
#93-7A-139 INFO. ON NEW 3RD CLUTCH SPRAG ASSEMBLY - (Apr 29, 1993)
#93-166-10 EXPANDABLE FOAM USAGE WITH COLLISION DAMAGE REPAIRS - (Apr 5, 1993)
#93-10-203 EXPANDABLE FOAM USAGE WITH COLLISION DAMAGE REPAIRS - (Apr 5, 1993)
#93-161-8A CUSTOMER COMEBACKS FOR INOP. BACKGROUND LIGHTING - (Mar 31, 1993)
#93-8A-117 CUSTOMER COMEBACKS FOR INOP. BACKGROUND LIGHTING - (Mar 31, 1993)
#93-156-3B CREAKING NOISE AT STEERING COLUMN (PROVIDE CLEARANCE) - (Mar 22, 1993)
#93-10-190 CREAKING NOISE AT STEERING COLUMN (PROVIDE CLEARANCE) - (Mar 22, 1993)
#38-30-01A ILLUSTRATED STEERING SYSTEM BLEED PROCEDURE - (Mar 16, 1993)
#33-50-05 REAR CALIPER SERVICE PROCEDURE - (Mar 4, 1993)
#93-137-5 BRAKE PAD LIFE, BRAKE NOISE OR BRAKE PEDAL EFFORT - (Mar 3, 1993)
#93-5-112 BRAKE PAD LIFE, BRAKE NOISE OR BRAKE PEDAL EFFORT - (Mar 3, 1993)
#93-133-10 BINDING/STICKING LOCK CYLINDER RECOMMENDED LUBRICATIONS - (Mar 1, 1993)
#93-58A-10 INDUSTRIAL FALLOUT/RAIL DUST DAMAGE TO BASE COAT/CLEAR COAT - (Feb 1, 1993)
#93-98-7A INFO. ON AUTOMATIC TRANS. FLUID LEVEL CHECKING PROCEDURE - (Jan 26, 1993)
#93-7A-125 INFO. ON AUTOMATIC TRANS. FLUID LEVEL CHECKING PROCEDURE - (Jan 26, 1993)
#93-81-9 INFO. ON REMOTE KEYLESS ENTRY (RKE) TRANSMITTER - (Jan 6, 1993)
#93-9-108 INFO. ON REMOTE KEYLESS ENTRY (RKE) TRANSMITTER - (Jan 6, 1993)
