jackhartjr Posted July 25, 2010 Report Posted July 25, 2010 Hi folks, off hand anyone know what size the 5 screws that hold the dash insert around the instrument cluster are? They go under the top of it. Thanks a ton! Jack (All five of mine are missing.) Quote
bg35765 Posted July 28, 2010 Report Posted July 28, 2010 I can't give you a screw number that tells you the thickness of the screw. But the thickness is the same as the other screws you'll find in the dashboard, like the ones that hold the trim piece under the steering column. What is different about those 5 screws is the length. I would guess that all the other screws in the dash are about 7/8". But those five are much shorter. They are maybe 1/2" in depth. And I think the screw head may be a little wider than the others. Quote
GnatGoSplat Posted July 28, 2010 Report Posted July 28, 2010 The ones for the dash bezel? On 91-94 verts, it should be taper-head Phillips screws with integrated tapered washer. Everything else is 7mm hex. Quote
