Ryan from Ohio Posted July 24, 2010 Report Posted July 24, 2010 Hi Guys, Seriously considering a 95 cutlass vert. Besides needing a new top- what are common issues or things to look for on a car like this? My Alero may be sold today and I may be driving 2+ hours away to look at this vert. Not sure what motor is in it. I have owned the 3400 DOHC (dont care for), 2.8, 3.1, 3100 and 3400 and now a 3800 (Riviera). So I know my way around the engines OK except the 3400 DOHC (was a young pup then). Thanks for the info! Quote
Crazy K Posted July 24, 2010 Report Posted July 24, 2010 vert issues: leaks holes in floor under rear seat from leaking structural rust bad rear window motors. bad top bad top cables bad rear window If it has a 3.4, you NEED to inspect the belt. on the passanger front corner, there is a black inspection cover. two 8mm bolts remove it (91-93 have a second cover that comes off first, also 2 more 8mm) and check the belt for uneven wear and damage. the belt can be slightly off center, but it should not be off the edge pully. With a flashlight you should be able to see the teeth and make sure no dryrot is occurring. look for oil leaks... and you will definitely find some.... Quote
Galaxie500XL Posted July 25, 2010 Report Posted July 25, 2010 +1,000,000 on the leaks. My '95 convertible literally had 6 inches of water in the spare tire well when I first bought it. But for sheer fun, a LQ1 Cutlass runs rings around my old LeBaron convertible. Well worth the trouble. Quote
