Myotis1134 Posted July 12, 2010 Report Posted July 12, 2010 Replaced my transmission gasket easily, but I'm on the oil pan now, and what a pain in the ass so far. I have removed everything I need to for access, and have pulled all the bolts out of the pan so it's moving around, but is caught up near the flywheel. I can see some sort of big ass retainer that prevents the flywheel-end of the pan from falling down, but I can't figure out how to release it. If someone doesn't tell me how to work this bastard by tomorrow, i'm going to just rip it out. Quote
GTP091 Posted July 12, 2010 Report Posted July 12, 2010 GM service manual says the oil pan is only removable with the engine out of the vehicle. you may be able to seperate the engine from the subframe and lower the subframe slightly to get enough clearance. Quote
Myotis1134 Posted July 12, 2010 Author Report Posted July 12, 2010 My bad, should have clarified. I currently have no sub-frame on the vehicle, and the engine and transmission are suspended from an engine-hoist. I am near the end of replacing the sub-frame, and figured what the hell- might as well fix a few things while it's open. I did the transmission gasket yesterday, and most of the oil pan today, but the bastard is hanging up on something between it and the flywheel, and I can't figure out how to get it loose. I did crank on it, but stopped before it got out of hand. the oil pan has no bolts in it, and I can move it slightly so I know there are no more bolts, but some kind of retainer clip is not allowing it to come loose. I swear if this turns out to be something simple I'm going to be pissed. Quote
Myotis1134 Posted July 13, 2010 Author Report Posted July 13, 2010 Seriously people, I don't have a clue on how to get this thing out. To specify a little more, this is happening on a 1991 Chevy Lumina Euro 3.1. I'm about to dink around with it some more, but I'm starting to lean towards brute force. Quote
Crazy K Posted July 13, 2010 Report Posted July 13, 2010 Is the metal brace that holds the lower engine mount still in?????? pics?????/ Quote
Galaxie500XL Posted July 13, 2010 Report Posted July 13, 2010 I'm wondering if one of the crank throws is catching something inside the pan...have you tried rotating the crank a little by hand? Quote
AL Posted July 13, 2010 Report Posted July 13, 2010 I remember having this problem with my 91, But I dont remember how I got around to fixing it Quote
Artemis Posted July 15, 2010 Report Posted July 15, 2010 Maybe the 91 didn't have this.... but how about the oil level sensor, have you removed it? Couldn't get my oil pan off without removing mine. Quote
GOT2B GM Posted July 15, 2010 Report Posted July 15, 2010 Thinking only 96+ LQ1s had the oil level sensor... This is a LH0...not thinking there is a oil level sensor. Quote
Myotis1134 Posted July 15, 2010 Author Report Posted July 15, 2010 Got it off. Turned out to be one last bolt in the pan waaaaaay back between the transmission where I couldn't see the bastard. What I thought was a retainer, turned out to be just that, but it had one last bolt as well ( only it was so caked with shit that I didn't know it was there until I started scraping). Sorry for the false alarm, but needless to say I feel like an idiot. Thanks people. Quote
