bad new for my cutlass....
grrr.. baddddd
after a lot of works on my 94' cutlasss... !!!!!!
-GTP dash swap with HUD DIC, center console, door trim change with all GP interior door (lach. look etc)
-HM-284 swap
-rear coilover swap
-lowering each corner
-new gaz tank..
-Full LEDs light conversion
etc etc etc
my F*****ing VSS break and fall in my transmission...... big bang.... bad noise from my differencial....
clokclokclokclokclokc when it's on compression..
I'm very angry.....
I willl post pics when I load on my pc....
it's my ....... VSS
I make a oilchange, just to see what will fall...
now..... I don't know what I do with this ........ cutlass... after everything is working, I could ride with only three weeks ....:mad:
I'm having a hard time trying to figure out what happened.... But I hope you can fix her!!!!!!!!!!!!!!!!!!!
I don't know too....
wednesday night.. cruised at 115km/h on highway.... my speedo stop working... the next day.. I run at my parent's house to check this.. but on my trip, on 4 gear.. I hear a big noise comeout under the hood.... all my speed work fine, same acceleration etc ... but when I loose the gaz I hear clokclokclokclok from driver side,
I think it's on my differential...
I think, because each gear work fine, no less power... but I hear noise when I turn left wheel
I had jack my car and start it, put in gear... when I put gaz, no noise, but when I dont touch the gaz... I hear this noise, and same on neutral possition and in clutch press..
my 282 threw a spider gear and broke off the tip of the VSS. there is a pic of the differential and inside the case in this thread. http://www.w-body.com/showthread.php/46174-88-is-back-after-throwing-spider-gear./page2?highlight=phantom+grip
I got a few miles after the spider gear blew out of the case. but first it bounced around in there and bashed up everything including the VSS.
