questions about 3.4 dohc 5 speed???
im looking at putting a 3.4 dohc in my 1994 Gran Prix. what transmisions are used for a 5 speed with that motor? Does anyone know of anyone who has already done this? If so did they run into alot of problems?? Any help would be much appreciated....
Muncie/Getrag 284. It's a tad beefier than the 282, has a pull type clutch, and repairs/mods are insane costly as well as parts. It's not a common tranny, but you can find them.
I would personally suggest the 282 for obvious reasons.
If you go ahead with the 284 swap, just find a junked out 5-speed z-34 or just about any 3.4 with a 5 speed. Take everything from the trans to the shifter and all things in between. I would suggest the same for the 282.
learn A LOT b4 looking seriously into this btw. trust me, its a pita just taking my motor/tranny out and putting it back in.
Well my friend is a mechanic whos also doing an engine swap on his car, and im doing all the vehicle body repair. The only thing is should the motor fit in or are there mods that need to be done????
Guest TurboSedan
VERY do-able, the DOHC/Getrag (282 or 284) will fit fine. you'll actually have more clearance with the 5-speed since they are smaller than the auto trannies are. at least my 282 was much smaller and a helluva lot lighter than my original 4T60. your BIG problem will be mounting the clutch pedal. i believe the dash changed in '94 and there was no provision for the clutch pedal mount. bummer but it can be done. i believe someone on this forum swapped a Getrag 284 5-speed into his later model ('94+....forgot which car he had :? ) hth somewhat anyway
joshua
It was soccerplyrgtp, he had that cool looking blue color that everyone loves on his coupe. I haven't seen him aorund in a while.
