willsboattail Posted July 6, 2010 Report Posted July 6, 2010 1993 Cultass Convertible 3.4L V6 - - - - - - - My temo gauge is running over 200 degrees. Idles nearing 220 degrees. Cools when moving. Electric fans do not seem to be running. Both fuses appear OK and coolant level is topped off. What do I look for next?????? Kevin in ND Quote
tornado_735 Posted July 6, 2010 Report Posted July 6, 2010 1993 Cultass Convertible 3.4L V6 - - - - - - - My temo gauge is running over 200 degrees. Idles nearing 220 degrees. Cools when moving. Electric fans do not seem to be running. Both fuses appear OK and coolant level is topped off. What do I look for next?????? Kevin in ND Possibly a failing thermostat. Quote
94 olds vert Posted July 6, 2010 Report Posted July 6, 2010 My cutlass with the 3.4 might get up to 215-220* on a hot day when sitting in traffic. But usually cools off when I get moving again. Usually stays around 200. I've replaced both my radiator and thermostat. If you think your rad core might be clogged blow it out with compressed air and then rinse with a garden hose. I would not use a pressure washer that might be too harsh on the fins. If your radiator fluid is old you might want to flush it. Quote
Galaxie500XL Posted July 6, 2010 Report Posted July 6, 2010 Do the fans come on when the A/C is switched on? At least one should any time the A/C is running. If so, that eliminates a bunch of things. Quote
WhatTheFehl Posted July 6, 2010 Report Posted July 6, 2010 You checked the cooling fan relays, correct? Cooling fan temperature sensor, on my 3100 it is near/behind the throttle body, I would assume on your LQ1 it is in a similar place. Quote
94 olds vert Posted July 6, 2010 Report Posted July 6, 2010 You checked the cooling fan relays, correct? Cooling fan temperature sensor, on my 3100 it is near/behind the throttle body, I would assume on your LQ1 it is in a similar place. You are correct. Quote
willsboattail Posted July 6, 2010 Author Report Posted July 6, 2010 Do the fans come on when the A/C is switched on? At least one should any time the A/C is running. If so, that eliminates a bunch of things. Yes, 1 fan on with A/C Relays??? Where are relays??? :)Thanks all, things maybe OK if temp should be that high??!! Kevin in ND Quote
WhatTheFehl Posted July 6, 2010 Report Posted July 6, 2010 Relays are in the fuse panel in the engine compartment. I think the originals were green... its a plastic block about an inch square... Quote
RobertISaar Posted July 6, 2010 Report Posted July 6, 2010 those temps are perfectly normal... your stat is 195*, and the fans aren't supposed to kick on until at least ~230 anyways, depending on BCC... Quote
Highmilagecutlass Posted August 14, 2010 Report Posted August 14, 2010 Robert.. you must be a mechanic because tend to back up your opion with facts.. Quote
RobertISaar Posted August 14, 2010 Report Posted August 14, 2010 Robert.. you must be a mechanic because tend to back up your opion with facts.. my "opinions" usually aren't opinions, they are facts. Quote
occupant Posted August 14, 2010 Report Posted August 14, 2010 And what Robert says is true, and the reason being the computer needs the engine running at 195 or above to control fuel and timing properly. The manufacturers assume the car will always have the right cooling system composition (50/50 coolant and distilled water) and the right amount of pressure (anywhere from 14 to 22lbs depending on the vehicle) in order to protect the engine at temps from 195 to 250 or so. When part of the cooling system fails, either by neglect, wear, abuse, electrical problems, or mechanical failure...the engine is no longer protected as well and the computer does NOT care. So keep up on that cooling system! Quote
Highmilagecutlass Posted August 14, 2010 Report Posted August 14, 2010 my "opinions" usually aren't opinions, they are facts. ok..I get it..I mispelled opinion..not the first..wont be the last time Quote
RobertISaar Posted August 14, 2010 Report Posted August 14, 2010 huh? no, i wasn't making fun of your spelling, just pointing out that my opinions are generally concepts, theories and facts that everyone has everyone knows are ture or assume to be true. Quote
