Night Fury Posted July 4, 2010 Report Posted July 4, 2010 Hokay...... This just started happening today, completely out of the blue. Like, it literally startled the crap out of me. Unlike last time, idle is perfect and it isn't dying due to it. It's cutting out or something under acceleration. Like bad. It's weird though because its kinda hard to duplicate. But when it happens..... it is VERY harsh, its like a whole bank gets shut off or something, so the engine is just slamming around in the bay and it sounds like it's gonna fucking blow, but when it isn't happening, everything is perfect and smooth all the way to redline. When happening, the rpm gauge shoots down very rapidly, like its actually getting pulled down rather than just floating down. Not to mention the needle is flying EVERYWHERE. I've got the camera in the car to try to catch it. Quote
birdman Posted July 4, 2010 Report Posted July 4, 2010 are all your battery cables tight? mabey check your grounds too? i was with a buddy once when the batt cable came undone and the gauges dropped like a rock, (and the car died) that kind of sounds like whats happening here. Quote
Night Fury Posted July 4, 2010 Author Report Posted July 4, 2010 I kinda thought about that, but headlights/wipers/etc have no change, as well as all other gauges are fine too and don't drop like the rpm one does. Quote
Night Fury Posted July 4, 2010 Author Report Posted July 4, 2010 And it's not dying. I had a escort with bad cables and it would die instantly when it happened like you said Quote
birdman Posted July 4, 2010 Report Posted July 4, 2010 well then i would look at the crank sensor, not that im an expert by any means but i believe the tach runs off the crank sensor and the car will not run if its dead so mabey its on its way out? Quote
Night Fury Posted July 4, 2010 Author Report Posted July 4, 2010 That was my second thought................ hmmmmmm Quote
birdman Posted July 4, 2010 Report Posted July 4, 2010 i did one on my lumina, sooo not fun, they like to get stuck in the hole and you have to pry them out, i broke mine but not enough to where i couldnt pry it out still, but from what i hear if you break it off bad enough you have to punch the rest into the motor and drop the pan to get the pieces out. i could be wrong though. if you do it i would advise taking you time and try to pry evenly on both sides. Quote
AL Posted July 5, 2010 Report Posted July 5, 2010 It did that shit to me all the time! I replace the plugs and wires and it was fine for 1000 miles... Quote
RobertISaar Posted July 5, 2010 Report Posted July 5, 2010 icm? very possible... the PCM/PROM dying is also a possibility. Quote
tornado_735 Posted July 5, 2010 Report Posted July 5, 2010 icm? I'll second this. When the one in my Olds died, it started missing something fierce, and it had no power. Then it would stop, be good for a little while, then start missing again. Turned out to be the ICM, and it fried the coil. Quote
birdman Posted July 5, 2010 Report Posted July 5, 2010 i might have a spare icm if you would want to give it a try. Quote
slick Posted July 5, 2010 Report Posted July 5, 2010 100% electrical/ignition related. Start checking grounds, icm, coils (heat soak is VERY possible), plugs, wires, etc... Quote
AL Posted July 5, 2010 Report Posted July 5, 2010 He just text me and said it left him stranded... Damn that car Quote
spiderw31 Posted July 5, 2010 Report Posted July 5, 2010 I'm gonna go with either the ICM or CKP. Quote
mra32 Posted July 5, 2010 Report Posted July 5, 2010 if you have access to another known good pcm, swap them, and remember to swap the PROM over. my car was wild similar to yours when mine took a shit Quote
Night Fury Posted July 5, 2010 Author Report Posted July 5, 2010 I has a vid. And like Al said it left me stranded tonight. I don't want to spend a cent on this car, but if it's just one part I'm ok with it. I DO NOT want to fucking start replacing parts willy nilly and waste money. But yeah, vid shortly!!!! Quote
Night Fury Posted July 5, 2010 Author Report Posted July 5, 2010 Enjoy: Watch the tachometer and ignore the rain! [video=youtube;UT-jksTPZ8g] Quote
spiderw31 Posted July 5, 2010 Report Posted July 5, 2010 That sure could be the PCM, but I'm still gonna guess the ICM. Quote
RobertISaar Posted July 5, 2010 Report Posted July 5, 2010 now changing my vote to ICM... if the PCM or PROM was going, then the speedo should have dropped like a fly as well. Quote
mra32 Posted July 6, 2010 Report Posted July 6, 2010 now changing my vote to ICM... if the PCM or PROM was going, then the speedo should have dropped like a fly as well. it was a while ago and i dont have all them fancy gauges, but when my PCM shit the bed, speedo was fine, but like it would not be able to receive/process info from various sensors, making it run like doo doo. It was bucking really hard on acceleration sometimes, would idle itself up to 30mph quickly, would fuck up for extended periods of time, with me flooring it on the highway, it bucking the whole time going 40. I'll try to find my thread. Quote
mra32 Posted July 6, 2010 Report Posted July 6, 2010 so heres my thread...now im thinking its not a computer in your case, but worth a shot if you have access, its like 7 bolts, all 10mm http://www.w-body.com/showthread.php/39032-Bad-ECM?highlight=computer Quote
Night Fury Posted July 6, 2010 Author Report Posted July 6, 2010 The thing is its really intermittent. Like I drove it all the way home today. I was nice to it and it drove PERFECT. But one block from home I figured I'd really get into the throttle, and sure enough it did it again, then stalled, then wouldn't re-start. But I drove it a good 4 miles perfectly before I got in it and it did that Quote
Night Fury Posted July 6, 2010 Author Report Posted July 6, 2010 I keep meaning to check the codes dangit! I'll go do that in a few Quote
