Heres a question for the HP Tuners guys, i get a service veichle soon light kind of randomly and it seems to be distance related when it does come on. Q1, is there any way to see the codes for the SVL? Q2, is there a way to see wheel speed sensor data with HPT?
you can see what the codes are while datloging with vcm scanner. As far as wheel speed sensor data, I don't think so since that is through the bcm. You may be able to chart the corect pid though since you can add alot of them to the scanner display
i was watching the codes for the check engine light before and after the service veichle light came and none of the codes changed. but i wasnt scanning, is there another menu besides the regular dtc menu?
