I am wondering where I might be able to come across the "beltline" or lower window trim that wraps from under the rear window to the quarter windows. It is the plastic coated black strip that goes between the body and the glass.
I have the piece under the drivers quarter window that is sticking out, bent and will not pop back in anymore. Its in a convenient spot to catch your clothes on while getting in or out of the car.
Anyone else have this same problem with their Cutlass?
Thank you,
Tim
  • 3 months later...
Mine did the same thing to, I used some stuff called locktite to glue that plastic to it and thats seemed to do the trick for these last couple of months but i sure any kind of out door adhesive would work. Hope this helps. Are your refering to the lower part of the windshield?
