bronze93 Posted June 19, 2010 Report Posted June 19, 2010 I need a new exhaust from the header all the way back. Where's a cheap place to buy a replacement from? Quote
jtwmechanic Posted June 20, 2010 Report Posted June 20, 2010 intense racing, w-body store both carry bolt on exhaust i think? there is a local shop near me that will do what you are looking for, something like new downpipe into dual out the back like factory but larger diameter pipe using your cat and quiet stock like mufflers for around 175.00.that is not including a high flow cat or performance mufflers, those are higher end products and will cost more.i have an appointment for next week to have my 96 L67 CUTTY done. he is going to make a 3" downpipe, eliminate my cat because there are no state emmissions here, continue with 3" pipe to the rear split it to duals at the monoleaf and use borla mufflers, one on each side with twin tips.my exhaust out the door with mufflers will be about 300.00.i am thinking about adding an electric cutout too. bet if you look around your area you can find a similar deal. i am using borla because i don't want that fart can sound like a ricer. Quote
Euro Posted June 20, 2010 Report Posted June 20, 2010 Intense or W-body Store doesn't carry exhaust for 1st Gens. Autozone might? Otherwise get one made at a muffler shop would be my guess. Quote
Andrew Posted June 20, 2010 Report Posted June 20, 2010 custom at an exhaust shop is your only route. make sure they use a mandrel bender! Quote
Mach 5 Posted June 20, 2010 Report Posted June 20, 2010 Isnt there a guy on here that can make one? I forget where I had seen it. Quote
jake91 Posted June 20, 2010 Report Posted June 20, 2010 OVERKILLENGINEERINGMOTORSPORTS. sells a dp back for like 300 minus cat res muffs i would rcomend running a 16in to 18in glaspack as a res and magnaflow 12226 mufflers Quote
Mysteriphys Posted June 20, 2010 Report Posted June 20, 2010 just a note, fuel injected engines need back-pressure to function properly, so if you're just looking to do a stocker swap, you might think of looking around your local j/y for an exhaust in better shape than yours. try not to go bigger than 2" on anything past the cat(s). Quote
White93z34 Posted June 20, 2010 Report Posted June 20, 2010 OVERKILLENGINEERINGMOTORSPORTS. sells a dp back for like 300 minus cat res muffs i would rcomend running a 16in to 18in glaspack as a res and magnaflow 12226 mufflers For the price the http://www.overkillengineeringmotorsports.com exhaust is a alright deal, but be prepared for it to fit for shit. The shop that put mine on had to really fight with it to make it work almost-right Quote
jeremy Posted June 20, 2010 Report Posted June 20, 2010 OVERKILLENGINEERINGMOTORSPORTS. sells a dp back for like 300 minus cat res muffs that system fits like complete dog shit on the two or three cars that I have seen with it installed.....i sure as hell wouldn't pay that much money to have it end up looking like a$$ ....go find a good local exhaust shop and have them build you a nice setup.... Quote
GOT2B GM Posted June 20, 2010 Report Posted June 20, 2010 which is dissapointing to say the least, I have an 2.5" SS OEM catback as well awaiting install on the TGP Quote
Artemis Posted June 21, 2010 Report Posted June 21, 2010 that system fits like complete dog shit on the two or three cars that I have seen with it installed.....i sure as hell wouldn't pay that much money to have it end up looking like a$$ ....go find a good local exhaust shop and have them build you a nice setup.... Mine fit perfectly, exhaust shop had no issues at all. Quote
jtwmechanic Posted June 22, 2010 Report Posted June 22, 2010 OVERKILLENGINEERINGMOTORSPORTS. sells a dp back for like 300 minus cat res muffs i would rcomend running a 16in to 18in glaspack as a res and magnaflow 12226 mufflers is this what your running, if so how about a sound clip? Quote
jake91 Posted June 22, 2010 Report Posted June 22, 2010 no im just running stock to 11126 mufflers Quote
jtwmechanic Posted June 22, 2010 Report Posted June 22, 2010 what kind of sound do they omit, is it low and throaty or what? i want to replicate that euro sport car sound not a pissed off bumble bee!! Quote
Brian P Posted June 22, 2010 Report Posted June 22, 2010 that system fits like complete dog shit on the two or three cars that I have seen with it installed.....i sure as hell wouldn't pay that much money to have it end up looking like a$$ ....go find a good local exhaust shop and have them build you a nice setup.... Mine was all fine except the extension pipe for the LH muffler. It was bent in the wrong spot, forcing me to use a 3" extension adapter. The only other thing I don't like is the angle and design of the LH pipe... way off. Quote
jake91 Posted June 22, 2010 Report Posted June 22, 2010 what kind of sound do they omit, is it low and throaty or what? i want to replicate that euro sport car sound not a pissed off bumble bee!! well i have the lq1 but here [video=youtube;p9kC9k-MxGQ] Quote
jtwmechanic Posted June 22, 2010 Report Posted June 22, 2010 awsome man, thanks! that is almost exactly what i want. do you think the glasspack for a resonator would deepen the effect. Quote
WhatTheFehl Posted June 22, 2010 Report Posted June 22, 2010 what kind of sound do they omit, is it low and throaty or what? i want to replicate that euro sport car sound not a pissed off bumble bee!! [video=youtube;HBARte3_Uvs] My 3100 with Cherry Bomb glasspacks in place of the stock mufflers. Quote
slick Posted June 22, 2010 Report Posted June 22, 2010 Rockauto.com, amazon.com, and most tire/auto repair shops and order replacement pipes. Quote
jtwmechanic Posted June 22, 2010 Report Posted June 22, 2010 that sounds really good too. wonder what the borla mufflers will sound like. Quote
WhatTheFehl Posted June 22, 2010 Report Posted June 22, 2010 I'm not sure, but mine is probably one of the cheapest exhaust mods you can do. Cherry Bomb glasspacks are the same or cheaper than stockers. The only problem is that they need welded, which I had done when my car went for inspection. Other than that my exhaust is completely stock. I still have the stock cat, pipe, etc. Quote
jtwmechanic Posted June 22, 2010 Report Posted June 22, 2010 just got done listening to sound clips on you tube. i am going with borla!!!! costs more, but the end result will be worth it. Quote
bronze93 Posted June 23, 2010 Author Report Posted June 23, 2010 Alright I have to admit I cheaped out and replaced from the exhaust header back from Rock Auto. Everything fits good but I ordered the wrong manifold gasket so I sit and wait for it to come in. What is the manifold gasket made out of, metal? And how do you get the old one off? Really appreciate all the help you guys are giving me and can't wait until I can get the GTP on the road. Mike Quote
slick Posted June 24, 2010 Report Posted June 24, 2010 Metal donut, is that what you are referring to? Quote
Addicted to eaton Posted June 24, 2010 Report Posted June 24, 2010 Thats what i got out of it chris. Quote
