bronze93 Posted June 19, 2010 Report Posted June 19, 2010 (edited) The front end of the GTP feels like it is floating when I'm driving it. I just replaced the outer tie rods and had an alignment done. Could it be tire sidewall sway? The tires on there are junk with sidewall dry rot. Any help appreciated. Thanks 1994 Pontiac Grand Prix GTP Edited June 19, 2010 by bronze93 Quote
White93z34 Posted June 20, 2010 Report Posted June 20, 2010 Well you say your tires are junk, and I'd guess that your struts are 16 years old now. So maybe start with struts? Quote
birdman Posted June 20, 2010 Report Posted June 20, 2010 the struts were bad on my lumina and hitting bumps over 35mph resulted in an almost perpetual up and down bounce, especially on the freeway. Quote
bronze93 Posted June 20, 2010 Author Report Posted June 20, 2010 The struts appear to be good. I tested them by pushing up and down on the fenders. I feels almost like driving a car with no sway bar. Quote
xtremerevolution Posted June 21, 2010 Report Posted June 21, 2010 How are the sway bar bushings? I'm going to go with bad tires. Don't ever underestimate tires. Sent from my T-Mobile myTouch 3G using Tapatalk Quote
RobertISaar Posted June 21, 2010 Report Posted June 21, 2010 How are the sway bar bushings? I'm going to go with bad tires. Don't ever underestimate tires. considering they are the only part of a vehicle to tough the road(normally), a LOT of issues could be caused by them. Quote
Addicted to eaton Posted June 21, 2010 Report Posted June 21, 2010 End links ok? Is the sway bar good... I have had one Break lol! Quote
GOT2B GM Posted June 21, 2010 Report Posted June 21, 2010 No end links on 1st gens. Just bushoings bolted directly to the control arm. Quote
Addicted to eaton Posted June 21, 2010 Report Posted June 21, 2010 you know, Having replaced them on two 95's, 89, and a 96. You would think i would know that LOL! Quote
bronze93 Posted June 25, 2010 Author Report Posted June 25, 2010 Well I may have a starting point over than tires for this problem. The PO decided I only needed 1 of the 2 bolts for the back of the subframe. I will have to check for more missing bolts. Quote
