bronze93 Posted June 14, 2010 Report Posted June 14, 2010 I picked up a GTP this weekend. I'll post pics as soon as I can but the car is out for inspection. It is not completely perfect. I have a few questions. When I shifted it into gear it didn't go but then I reved the engine a litte and it went in. I know this isn't normal any ideas. Also, the tach and speedo bounce to the beat when I turn the turn signals on. I'm also looking for a couple of interior parts : the vent on the passenger side charcoal in color, the rear map lights for the back seat charcoal in color, the passenger side coat clip charcaol in color, and the clips that hold the side mouldings on the fenders and quarter panels. Thanks for any help, Mike Quote
carkhz316 Posted June 14, 2010 Report Posted June 14, 2010 Unfortunately for your gear shifting issue, you may be looking at a new trans or rebuild in the near future. Quote
AL Posted June 15, 2010 Report Posted June 15, 2010 the gauges bouncing with the signals I think is a bad battery connection Quote
bronze93 Posted June 19, 2010 Author Report Posted June 19, 2010 Well, I found all the interior parts but still have to fix the trans and turn signal issue. Quote
91LuminaEuro Posted June 21, 2010 Report Posted June 21, 2010 this may sound silly, but did you check the transmission fluid? Check the fluid, a good fluid/filter change may help you squeeze some life out of the transmission until you can save to re-build or buy another one. Quote
