My car started having a clicking sound. Seems like it is coming from the area of right front wheel. It is pretty steady until I slow down to 15mph, then it completely stops. Any ideas?
thanks
Jeremy
Sounds like maybe a CV joint could be getting ready to fail. Does the clicking get any louder when your turn?
I've haven't noticed either way....
based on clicking alone, a CV is the most likely cause.
does it cause any kind of vibration?
In my experience, when a CV is on it's way out, it starts clicking in turns long before you get any noise while going straight.
I'm leaning towards a hub or a CV.
no vibration at all either.....anyway to troubleshoot to verify it is CV before blindly replacing?
Mine is doing the opposite, it's under 15 mph and it's as you turn the wheels. I would like to know as well... How hard are CV shaft's to do in these cars, (mine is a Lumina) but I'd imagine it's the same?
CV's as cake. and i have one going bad on the honda and it clicks under heavy load at low speeds and NOT in turns.
Jeremy I'd put my money on the hub, but who knows. May be something so simple as a harness against the wheel or something
could alawys jack the wheel up and shake things around, usually you can feel a bad hub.
Make sure there is nothing in your tire like a nail or something too
Good call, could even be a pebble stuck in the tread
definitely nothing in the tire
Figured mine out... finally had a second person to turn the wheel while I went under there and it's definitely the left strut on my car. I know that doesn't help you so now I'm going to go with a CV shaft for your car.
You might jack that wheel up, and try spinning the wheel back and forth with the trans in park. I bet you'd get some noise if it was the CV.
  • 4 weeks later...
well, the bearing/hub definitely needs to be replaced because it is humming pretty good now....I am going to look at finding the correct p/n for the CV and the hub as I do think both are two separate issues...
.....btw, anyone have a write-up on CV replacement on the post-gens??
i may be able to pull something up in alldata...
