Chip Posted May 30, 2010 Report Posted May 30, 2010 I am getting an intermittant egr P0401 code on my 96 3.1 regal. I am noticing a slightly rough idle at times, and at others, smooth as can be. Is it worth just replacing the whole egr, or could the intake inlet be carboned up? Should I pull the upper intake first before spending $160.00 - $190.00 on new egr unit? Any insight from your experiences would be great. Thanks Quote
WhatTheFehl Posted May 30, 2010 Report Posted May 30, 2010 Oh, and I went through my EGR/TB cleaning hell yesterday. Quote
Chip Posted May 31, 2010 Author Report Posted May 31, 2010 Great great clip. Thanks a million. Will try it next weekend. BTW - Vehicle has 187,600, so I'm sure its due for some cleaning. Quote
WhatTheFehl Posted May 31, 2010 Report Posted May 31, 2010 No problem Be forewarned though, what they don't show you in the video is that the lower throttle body bolt is a PITA to get to because a coolant pipe runs right in front of it. It's not horrible, but it will take you a little time to get it off. And one more thing, make sure you get a new throttle body gasket before you attempt to do this. Mine completely disintegrated when I took the throttle body off (into like 6 or 7 pieces) so you chances are you won't be able to reuse it. Quote
Chip Posted January 4, 2011 Author Report Posted January 4, 2011 No problem Be forewarned though, what they don't show you in the video is that the lower throttle body bolt is a PITA to get to because a coolant pipe runs right in front of it. It's not horrible, but it will take you a little time to get it off. And one more thing, make sure you get a new throttle body gasket before you attempt to do this. Mine completely disintegrated when I took the throttle body off (into like 6 or 7 pieces) so you chances are you won't be able to reuse it. Finally got around to doing this job. You were spot on in saying that the lower TB bolt is a biotch! With the pressure the coolant tube was putting on it, I actually began to crossthread the lower bolt on reinstall. Luckily, the trusty metric tap set cleaned things up. I had that nub of carbon on the egr port and got it all cleaned out. Thanks again Quote
