BuickMan Posted May 28, 2010 Report Posted May 28, 2010 something is rattling under the hood on the passenger side when I'm idling. I can't tell if it's the engine or something else. There doesn't seem to be any change in engine performance. car still starts OK. Anybody know what it might be? Quote
AL Posted May 28, 2010 Report Posted May 28, 2010 possibly an exhaust heatshield... Pop the hood while its idling and listen for it Quote
xtremerevolution Posted May 28, 2010 Report Posted May 28, 2010 possibly an exhaust heatshield... Pop the hood while its idling and listen for it x2. Been there, done that. Quote
mediabandit Posted May 29, 2010 Report Posted May 29, 2010 Also check your A/C the clutch goes bad in them and it sounds like a marble in a tin can when it sits idling. Quote
jtwmechanic Posted May 31, 2010 Report Posted May 31, 2010 pull the belt and start the engine for a second if you don't hear the rattle then that will eliminate the engine or harmonic balancer. if you still hear it then check the balancer, they have been known to come apart. after that definately probally the exaust or something? Quote
RobertISaar Posted May 31, 2010 Report Posted May 31, 2010 i have roughly half of the exhaust heatshielding pulled off of the MC(all of the underside pieces, oddly enough), but i never heard them making noise even when they were just barely holding on... other vehicles however, you could see the damn thing tapping whatever it could touch, especially during a gear change or reverse/drive transition. Quote
