ron350 Posted May 28, 2010 Report Posted May 28, 2010 (edited) How do you replace the master cylinder on an ABS 6 car? Edited September 29, 2013 by ron350 Quote
ron350 Posted September 23, 2013 Author Report Posted September 23, 2013 (edited) Edit. Edited September 29, 2013 by ron350 Quote
DesertEagle50 Posted September 23, 2013 Report Posted September 23, 2013 Wow that’s an old thread that has never been answered. I ended up using a used ABS/Master Cylinder assembly from the scrap yard. So you replaced your ABS/Master Cylinder and you didn't disassemble the original one you no longer needed? If so, that's a VI-O-LA-TION!!! I consider it my constitutional duty to disassemble every nonfunctional part I remove from a vehicle with the only rule being: Do Not Void the Core Credit. Maybe I suffer from an overabundance of free time, but I consider disassembling stuff to discover how it works a basic instinct like eating or f*cking or like the explorers who sailed into the Atlantic to see what lay over the horizon. I mean, you know someone else on a forum (#ME) could benefit from the knowledge acquired by disassembling a part in question especially when a manual says "Thou shall not replace, inspect or actuate without said overpriced proprietary tool." So are we mice or are we men? Who among us has attempted the fabled Delco/Delphi ABS-VI master cylinder swap without the loathsome Tech 1 scan tool? Quote
l67ss Posted September 23, 2013 Report Posted September 23, 2013 Prolly the same guy who sed dont do it w/o the scan tool So you replaced your ABS/Master Cylinder and you didn't disassemble the original one you no longer needed? If so, that's a VI-O-LA-TION!!! I consider it my constitutional duty to disassemble every nonfunctional part I remove from a vehicle with the only rule being: Do Not Void the Core Credit. Maybe I suffer from an overabundance of free time, but I consider disassembling stuff to discover how it works a basic instinct like eating or f*cking or like the explorers who sailed into the Atlantic to see what lay over the horizon. I mean, you know someone else on a forum (#ME) could benefit from the knowledge acquired by disassembling a part in question especially when a manual says "Thou shall not replace, inspect or actuate without said overpriced proprietary tool." So are we mice or are we men? Who among us has attempted the fabled Delco/Delphi ABS-VI master cylinder swap without the loathsome Tech 1 scan tool? Quote
Cutlass350 Posted September 24, 2013 Report Posted September 24, 2013 Who among us has attempted the fabled Delco/Delphi ABS-VI master cylinder swap without the loathsome Tech 1 scan tool? I can do it with no problem at all without a Tech-1 on my Olds Achieva! I have a newer Tech-II. FWIW, a long long time ago, there was a scan tool that read the weird Delco-IV OBD-I pinouts/standards (like on an Olds Achieva) and it was also able to issue a re-home command. My old ABS scanner died many years ago. I haven't seen on one ebay since. But, I also don't search for ancient ABS scanners. Quote
DesertEagle50 Posted September 26, 2013 Report Posted September 26, 2013 FWIW, a long long time ago, there was a scan tool that read the weird Delco-IV OBD-I pinouts/standards (like on an Olds Achieva) and it was also able to issue a re-home command. So the purpose of the Tech-1 or Tech-2 is to re-home the abs module? Quote
mfewtrail Posted September 29, 2013 Report Posted September 29, 2013 So the purpose of the Tech-1 or Tech-2 is to re-home the abs module? The purpose of the scan tool is to re-home the motor so that the brakes can be bled properly. For bleeding w/o a scan tool see one of the following links: http://www.aa1car.com/library/abs_bleeding.htm or http://www.saturnfans.com/forums/showthread.php?t=146855 @ Joe - The old scan tool that you're thinking of is probably the OTC ABS Reader. It will read the Delco IV and a lot of other older systems. I picked one up cheap a few years ago on ebay just to have. I can grab the part number off it later if anyone else is interested in trying to track one down. You're going to have to look on ebay or craigslist randomly to find one. They don't show up very often anymore. Quote
