zmanmike Posted May 24, 2010 Report Posted May 24, 2010 hello, iam trying to find a good place to put a trans temp probe in.. is there a good place to do this on my 1993 z34, also what is the "very"small cooler that is hooked to the inside of the radiator?? is it engine oil cooler or transmission oil cooler?? thanks mike Quote
mfewtrail Posted May 24, 2010 Report Posted May 24, 2010 There's a pressure testing port on top of the transaxle just below the top bracket area that most people use when wiring up a trans temp gauge in these cars. I'll see if I can find a picture for you. As for the thing near the radiator, it should be a trans fluid cooler. The oil cooler on that car should be in between the engine block and the oil filter. Quote
zmanmike Posted May 24, 2010 Author Report Posted May 24, 2010 thank you a pic would be freakin awesome!!!!!!!!!!!!!!!!!!!! i would love to use that test port rather than trying to splice into a cooler line... i was on ttop of the engine today with a flashlight trying to find that and i could not... thank you mike from michigan... Quote
mfewtrail Posted May 24, 2010 Report Posted May 24, 2010 I checked through the service manual quickly looking for a picture/diagram and couldn't come across one. You'll pretty much need to remove the airbox + tubing going to the throttle body to see the area I mentioned. I'll probably take a quick picture of that location on the transaxle and post it here sometime tomorrow for you. Quote
AL Posted May 24, 2010 Report Posted May 24, 2010 mfewtrail, think you can circle it in these pics, this trans is from a 93 DOHC gp Quote
zmanmike Posted May 24, 2010 Author Report Posted May 24, 2010 ok, is it behind the plennum/in between firewall.. i do not have a air box in the car and it is still looks tigt back there..((although i dont know what iam looking for,,,lol)) thanks for any any help..mike from michigan Quote
mfewtrail Posted May 25, 2010 Report Posted May 25, 2010 I forgot about taking a picture of that for you, but Al's picture will work. I circled the plug in this picture. Quote
